![]() | Home > In Car Electronics (L322) > Radio/CD stopped working and wont turn on. |
Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118 ![]() ![]() ![]() |
This happened to me a few weeks ago, i unplugged the 3 plugs on the amp and plugged them back in and it all burst back into life ???? |
Bagus Member Since: 14 Apr 2014 Location: London Posts: 202 ![]() ![]() ![]() |
Had a flat battery today so went off and bought a new Bosch 020.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
after fitting the battery did you set the steering parameters.. ... - .- -.
Arhh good point stan. Is that the old turn steering wheel full lock and back trick?
after a battery re-connect , turn steering fully left then fully right.. |
Nice to have a simple solution for once. I can sleep easy tonight.
Geo2toy Member Since: 04 Nov 2012 Location: Wiltshire Posts: 76 ![]() ![]() ![]() |
Hi Guys
Lyndasbottom Member Since: 23 Nov 2014 Location: Devon Posts: 9 ![]() ![]() ![]() |
Probably the BM54 pre-amp gone. This feeds into the DSP which relies on a signal from the radio. Try putting a 9V battery across across one of the speaker wires. This will prove the speakers works. If you get some noise the speakers are working which will support the pre-amp theory |
