Home > Maintenance & Mods (L322) > Silly door mirror question.....
2007 FF TDV8 Vogue... request from a friend... can you adjust how far down it dips when you stick it in reverse, he knows how to turn it on and off but recons it dips too low.....
Interestingly, if I turn mine on it does a little up/down/up/down dance before settling down.... can't find anything in the CCF on mine but wondered if the later ones were different... Pete
Post #288392 23rd Oct 2014 8:00pm
Richard
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Mine does the up down dance, perhaps its a 'feature'?
Post #288407 23rd Oct 2014 9:05pm
pretty sure i saw this in the owners manual Pete...when on dip you adjust lower or higher with the four way toggle.. ... - .- -.
Post #288408 23rd Oct 2014 9:06pm
RiccartonRR
On mine you select reverse (as long as the option is turned on) and then adjust the mirror to the desired height. Once happy press the seat M button followed by the memory button currently in use and Bob's your uncle (father in my case).
Post #288410 23rd Oct 2014 9:07pm
And the prize goes to Stan Thumbs Up
The procedure is in your handbook sir Bow down
Post #288413 23rd Oct 2014 9:12pm
he's a lying toad then, cause that was my first question to him... Pete
Post #288425 23rd Oct 2014 9:55pm
