![]() | Home > Maintenance & Mods (L322) > Engine blower running all the time? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
handy to know that those symptoms relate to a faulty fsr, glad its sorted alan.. |
'tis possible the fsr has gone again. One of my replacements "went" quite quickly. I noticed some shorting had been taking place around the connector, so it was possible I hadn't quite got it back together properly (had the same problem when i fitted new radiator and a hose blew off!)
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
its genuine LR.
Yes rear is seperate (fuse in rear ndfi will confirm) and has its own FSR too. .
So what's the common denominator then? |
Seems the problem is solved. Removed the FSR, checked the blower by bridging across the connector.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Glad that's sorted, wonder why it took the rear out as well, maybe the rear runs through the front as well..... Pete
^ it seems that way. The rear fan speed switch doesn't seem to do anything but is controlled by the front fan control.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
If you press the rear fan switch on the front central console, doesn't that allow fan speed adjustment (ie you can inhibit the rear control to stop the kiddies playing?) GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Is that the button on the bottom right hand side? |
That's the one..icon looks like air-flow lines |
Ah, I though that was for additional demisting for the rear side windows! |
TBH Alan..i only found out by accident |
