Home > Maintenance & Mods (L322) > Size of the hub nut?
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Think my passenger front wheel bearing is on its way out , before I start I wondered does anyone know if the hub nut needs some sort of special socket and what size will fit ?
Post #288073 22nd Oct 2014 8:33am
Mikey
36mm bi-hex Thumbs Up
Post #288074 22nd Oct 2014 8:37am
birchyman71
Cheers will get one before I start
Post #288087 22nd Oct 2014 10:41am
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
I'm sure I had that as a question on a recent sexual orientation form Rolling with laughter
Post #288118 22nd Oct 2014 2:55pm
birchyman71
Just changed passenger side wheel bearing today, to say it went well would be pushing it, was going to do drivers side aswell but the track rod end was so stuck it broke my ball joint separator, so sacked the drivers side.put it all back together. Passenger side ended up with the lower control arm still attached due to another uncooperative ball joint. Separated the hub and removed the race with grinder and chisel, but then none of my kit was big enough to fit the bearing so took it to a local garage who pressed it out and reassembled it all with his 10 ton press, back home and all back together total time 8 hours. On the plus side its alot quieter now.
Post #289637 29th Oct 2014 8:25pm
Shocked Shocked Shocked
Post #289681 29th Oct 2014 11:46pm
