Home > Technical (L322) > Dim sat nav and parkin sensors beeping..
PJS
Well when i turn the engine on the parking sensors go mad, unless i turn them off on the dashboard. And the satnav screen is really dim now. Changed the fuse the other week as the instruments all turned off, could it be both the instruments and the sat navs fuses? Or does the battery need changing etc?
Thanks, Peter.
Post #28773 21st Sep 2010 8:32pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Parking sensors - have you used a pressure washer on the car recently or are they very dirty or have you been through deep water?
Obvious I know, but could any little kiddies fingers have fiddled with the brilliance settings for the dash and sat-nav? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #28802 21st Sep 2010 11:01pm
PJS
The dirty parking sensors werent the problem. Anyone else?
Post #29883 29th Sep 2010 7:47pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
What year is it? Does the light flash on the parking sensor button when it beeps..... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #29885 29th Sep 2010 8:36pm
you've probably done this already but,have you checked each sensor to see if they are all working...turn them on via the dash switch and listen to each sensor , each should make a ticking noise, if it doesnt then thats your problem.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #29916 30th Sep 2010 8:25am
