Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Er... don't have a heated steering wheel, don't need one (not as soft as the rest of the southerners!), so I can use the connector for the heated wheel to make use of the slip ring for connectivity. I'll assume I can get a male connector from somewhere.
17th Feb 2013 3:14pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
hi all, been reading this thread a few times. i have the vogue model and bought a pair of 'powerfuluk' paddles. resoldered the boards as the youtube vids says. tested ok. about to fit them etc. -waiting for a cooler day, boiling at present, then i can play the powerfuluk 'piano music' as i fit them!
27th Jul 2013 5:41pm |
UPDATE. as above, i tapped into the RED wire, coming out of the slip ring on the wheel side, last one on right, this was ign live and key out 'dead'. so with that and an earth (on the wheel) powered the led's. the earth is the condition switched by paddles down to the console to change gear. can see at night but obviously cant see them lit in daytime. and used the heated wheel connections through slip ring. (red/brown and under slip ring there is a separate plug with the green and black (heater connection) and a brown if i remember. i cut and isolated them there. and ran a cable down to the centre console. yes, they work a treat.
30th Jul 2013 9:25am |
jeffhunt Member Since: 19 Oct 2014 Location: Hampshire Posts: 1 |
Hi guys, new to the site, I have read all the posts regarding the fitment of the wheel mounted change paddles to a 2010+ Range Rover Sport, has anyone found anywhere that can update the CCF file or any way around it?
19th Oct 2014 11:21am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
if its RRS info you want then you're on the wrong forum, try http://www.rrsport.co.uk/forum/ ... - .- -.
19th Oct 2014 11:28am |
ksskaret Member Since: 27 Oct 2013 Location: Tromsø Posts: 73 |
edit Range Rover TdV8 Autobiography MY2010
19th Oct 2014 1:39pm |
djensis Member Since: 11 Feb 2015 Location: kortrijk Posts: 1 |
Hy Matt,
11th Feb 2015 8:50pm |
if you have a sport then you are on the wrong forum, try here,
11th Feb 2015 8:55pm |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 |
Hi guys,
20th Feb 2015 5:56pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
go for the hard wire option, I don't have the diagram after my hard drive went up the wall but I am sure someone has it on here,
20th Feb 2015 7:06pm |
Hardwired is an option, however this option should work, I have tried to figure out the way it works and what could be causing this delay and why the paddles need to be held in for at least a second.
20th Feb 2015 11:05pm |
What are you using to power the transmitter
20th Feb 2015 11:51pm |
SCPB Member Since: 16 Jun 2015 Location: Surrey Posts: 72 |
Bit of an old thread resurrection but I am struggling to find the this jumper cable.
11th Aug 2015 7:17pm |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 |
Sorry to resurrect such an old thread, but seems more relevant than starting my own.
29th Jul 2016 10:40am |
