Home > Technical (L322) > loss of power / hesitation 3.6 TDV8 |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Good evening gents.
18th Oct 2014 9:44pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
P023D
18th Oct 2014 9:48pm |
Cheers Mikey....could it also potentially be related to the EGR's as I know they can be an issue?
18th Oct 2014 9:50pm |
If it was an EGR issue, it would have logged an EGR code too |
18th Oct 2014 10:23pm |
Sounds positive...fingers crossed for a split hose then...will post the outcome
18th Oct 2014 10:40pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Check both top inter cooler hoses, common problem. Happened to mine, have a look in the wiki I did a write up on how to swap one (logical and easy really). There is nothing that can't be fixed with a hammer😜😜
19th Oct 2014 7:08am |
Found it....a 2" split in the right hand Turbo hose!
19th Oct 2014 3:54pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Result! Got - 2017 SDV8 Autobiography in Loire Blue
19th Oct 2014 4:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
nice bit of 'first aid' there.. ... - .- -.
19th Oct 2014 4:07pm |
That's the monkey! Should hold fine until the replacement arrives. There is nothing that can't be fixed with a hammer😜😜
19th Oct 2014 4:58pm |
Cheers for the write up NMJ
19th Oct 2014 5:15pm |
Result |
19th Oct 2014 5:34pm |
Cheers for the heads-up Mikey...Do you have a list of fault codes we can publish or a link we can post for future use??
19th Oct 2014 6:29pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Nice cheap fix Paul, wonder how long it would last if you just left it????
19th Oct 2014 7:46pm |
