![]() | Home > Technical (L322) > injector fault |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
Dam My Hide I have just done the same thing and come back to the forum to find out and |
Put a little injector cleaner in at the next fuel stop - normally works a treat. |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 ![]() ![]() ![]() |
Hi Gary,
If that doesn't sort it, do a leak test to find faulty injector and replace, fairly straight forward (see wiki). Could possibly be fuel rail wiring loom which also tends to fail. .
Thanks joe90,
G'day Gazza your about an hour away from us down the Northern Road, I worked out of Richmond RAAF base for a bit a couple of years ago........ Back to the injector fault, I replaced the turbo just before I went to the UK and while they were out I had the injectors tested and they all came up well within specs so I'm sure there ok I'll look at the wiring next service Ziggy "Those who cannot remember the past are condemned to repeat it." George Santayana Puts away his cloth cap and donkey jacket Goes and sits in the naughty corner |
