Home > Technical (L322) > Van Aaken Smart Box
gibbsy
United Kingdom 2002 Range Rover Vogue Td6 Java Black
Van Aaken Smart Box
Hi
I have recently purchased this smart box from Ebay and after hours and hours of searching I cant find any info on connecting it up. If anybody can help it would be much appreciated.
Regards
Dave
Post #287056 17th Oct 2014 1:45pm
not a FF but it should give you an idea,
http://www.landyzone.co.uk/lz/f8/van-aaken...64980.html
http://forum.lro.com/viewtopic.php?f=19&t=22787
http://www.nosmokenopoke.com/forum/showthr...Tuning-Box ... - .- -.
Post #287058 17th Oct 2014 2:02pm
and this on this forum,
http://www.fullfatrr.com/forum/topic9576.html?highlight=van+aaken ... - .- -.
Post #287060 17th Oct 2014 2:19pm
gibbsy
Hi
Thanks very much for the response what are people's opinions on these is it worth
The effort to get this fitted.
Regards
Dave
Post #287183 17th Oct 2014 9:27pm
Googsy
Did you try calling the number on the device Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #287185 17th Oct 2014 9:32pm
gibbsy
Hi
No I havent, not knowing how old this is and reading they went out of business some time ago I didn't think it would go anywhere. Is there a way of telling how old this unit is?
Dave
Post #287187 17th Oct 2014 9:35pm
Hope they didn't go bust because of all the people suing them because their engines blew up!!!! Pete
Post #287190 17th Oct 2014 9:50pm
gibbsy
Hi
I'm guessing your not a fan?
Post #287194 17th Oct 2014 9:52pm
To be honest I've never heard of them, I'd do lots of googling though.... just to be sure.... had a few chipped diesels over the years and never had any bother from cheap boxes off the bay to proper remaps so I recon you'll be alright... does look a bit complicated though.... Pete
Post #287200 17th Oct 2014 10:29pm
They jump across the engine ECU plug... Unplug the ECU and you will find the wiring is the same so, the ECU plugs into one side and the other side plugs back into the ECU Thumbs Up
Post #287201 17th Oct 2014 10:30pm
gibbsy
What about the two leads at the top the black and brown one? The brown one has a metal loop terminal making me think it a power feed from the battery or an earth.
Dave
Post #287202 17th Oct 2014 10:35pm
Joncey
Jersey 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
The two extra leads look to be optional
Take a look at this video https://archive.org/details/TdiPerformanceChip
Post #287242 18th Oct 2014 8:16am
gibbsy
Hi
Thanks for all your replies, I will give it a go and see what happens.
Regards
Dave
Post #287679 20th Oct 2014 9:51am
Van Aaken were based in the village where I live and operated out of units on the TRRL site that's now earmarked for more Censored houses that we simply do not need or want.
I used them to tweak the mechanical Bosch injection pump on my 300Tdi 110 and, to be fair, they did an excellent job. They were far better than the other well-known (at the time) LR 'expert' who got more power but, looking back on the facts, had the pump running so high that I'm amazed the engine didn't blow up. By rights, it should have. VA knew what they were doing, to give them their dues.
I also bought one of their tuning boxes for my dad's BMW 320d and fitted that. Much as the item pictured above. This was back in 2007, by the way.
Seemed to improve things noticeably and the engine didn't go wrong in the two years after that.
But these days I'd go with a remap from a reputable company. Si. <This is my name.
Post #287688 20th Oct 2014 11:19am
gibbsy
Finally got it fitted and all seems fine.
I don't suppose anybody knows about changing the setting inside the box? I think they are called jumper plugs. It has two inside bridging two pins together at a time.
All help appreciated
Dave
Post #298490 12th Dec 2014 12:28am
