Home > General > 4.4td v 4.4petrol
andrew-a
4.4td v 4.4petrol
I have owned a 2003 4.4 petrol for the last 3 years and now looking for something newer. So today I tested a 4.4td on a 61 plate with 50k miles. I simply can't get over the fact that from standstill the car seems limp! The throttle response is slow and somehow disconnected from the engine. My 2003 seems more responsive and alive....is it me? Don't get me wrong, when the diesel got going, it really went, but somehow by then the fun had already gone. Am I just imagining it?
Post #286711 15th Oct 2014 10:41pm
Funnily enough i think quite the opposite. A high end motorcar should feel un-hurried and comfortable to travel and be driven in! Everytime i jump in a BMW engined 4.4FF (not the jag engined) i have to physically think for the first few minutes when pulling off so as not to break my bloody neck!
Go and drive any other engined FF and if you like the 4.4's throttle action, IMHO you will be just as disappointed with every other engine as you seem to be with the 4.4TDV8...
Hay, just my two penneth worth sir Bow down
Post #286720 15th Oct 2014 11:26pm
andrew-a
How does the 5.0SC compare? Is this more comparable to the old 4.4 petrol?
Post #286723 15th Oct 2014 11:36pm
Very few & far between around these parts Andrew... Most of our work is on pre 2011 FF's and 95% of them are derv Thumbs Up
Post #286724 15th Oct 2014 11:39pm
A remap will quickly cure this!
A lot of the 2012 disco 4 sdv6's suffered a similar lag(though I wasn't believed at the time!) but I believe they were flashed and the issue went away. You expect a bit of lag with a diesel and a turbo unit as well but not too much considering how quickly the electronics can respond to the request. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #286744 16th Oct 2014 1:57am
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I know exactly what you mean as I've owned two TDV8's before going petrol. The 5.0L Supercharged is a very sweet engine giving instant power delivery with no lag whatsoever.
Post #286750 16th Oct 2014 5:27am
It's the same with any diesel turbo fitted to an auto box, you start off from tickover and have to wait for the revs to build a bit before the turbo's come in and give all that torque, even if the stall speed of the torque convertor is raised you still have to wait for turbo lag...
My old Volvo XC70 was terrible for it, if you needed a quick getaway you had to left foot brake and build the revs and then go.... not a good idea if you want your TC to last long though.... Pete
Post #286753 16th Oct 2014 7:06am
I underestand completely. When I pull out the drive in my 4.4 V8 Petrol I often get a surprise as I put my foot down and the car surges forward and the revs build quickly as it literally shoots forward - and the noise! Makes me smile every time as its somehow not expected by my brain sitting in a Range Rover. Thumbs Up
Post #286758 16th Oct 2014 7:27am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I always thought my 4.4 petrol was quick off the mark but find the present 4.4 tdv8 even quicker.
I often get a glare from the passenger seat as we launch, might just be my size 11s though.
Ian
Post #286776 16th Oct 2014 8:58am
The Jag engined cars don't do this though... SC or NA don't... Maybe they mapped it out during the design phase? Question
Post #286778 16th Oct 2014 9:18am
RR2008HSE
^ Thumbs Up
The Jag ones build very linearly. No surprises. If you want fast, NOW you plant your foot and get it. Otherwise, they're very easy to drive comfortably.
Post #286994 17th Oct 2014 2:07am
Yes for me its a good argument for the cheaper 4.4 BMW V8 as it a VERY free revving engine but overall the Jag engined car is obviously a better buy.
Post #286999 17th Oct 2014 7:20am
ebajema
I find the 5.0 SC quite instantly there when you want to and also able to drive "smoothly" and "stately" if you like Wink.
If you felt the 4.4 TDV is not too responsive, maybe try to compare it to others and see if it is just the one. Also when you drove it, did you give it a bit of welly for a bit so see if it was "coked up" (if that even happens to the modern diesel FFRRs). MY 2010 5.0 SC Galway green and sand interior!!
Post #287037 17th Oct 2014 12:15pm
