Home > In Car Electronics (L322) > No beeps from rar of car when caravan attached
philmc79
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I have changed the wiring from a 7 pin socket to a 13pin euro plug using a proper wiring loom from Land Rover and removing a generic wiring loom since doing this there is no beeping when the indicators are activated as it did on the generic loom, is this correct or have i missed something on the installation on the proper loom?
Any help will be great
Post #286682 15th Oct 2014 7:06pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
I have standard 7 pin OEM electrics on my 2007 and there's never been a beep on indication... Question GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #286687 15th Oct 2014 7:17pm
philmc79
Thanks for that i was just checking i think the old one prob did it as a confidence thing as the car does the checking for you.
Again thanks
Post #286688 15th Oct 2014 7:19pm
mzplcg
Aftermarket looms often contain a buzzer whereas the factory one does not. As long as you have the green trace light on the dash everything's OK
Post #286689 15th Oct 2014 7:21pm
The wiring relay in the boot on generic stuff is what beeps, if your new stuff is wired in ok you should have a green trailer light on the dash, the on board electronics will then warn if bulbs have failed. There is nothing that can't be fixed with a hammer😜😜
Post #286691 15th Oct 2014 7:37pm
mjdronfield
As others have said, you don't get the beeping as you have the telltale on the dash. The proper way that it should work. Smile
When I first read your post, I thought you meant from the PDC, which of course should not work on rear when caravan attached.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #286695 15th Oct 2014 7:47pm
miggit
Tell tail on the dash????????
All mine does is make the indicators go into a fit if theres a bulb out on the trailer, and or bong me to death with the screen of doom 'Check Trailer Lights'. I do however get the suspension hight lock on, and you can't over ride it. Oh and my reversing sensors in the rear get knocked out, but the rain can do that too Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #286732 15th Oct 2014 11:08pm
It all depends on how your trailer setup is set in the ccf.
Mine lets me change height but does indeed knock out the rear sensors Smile
You should get a light on the dash in green that is a picture of a trailer, looks like a Stanley trailer to me! Not sure what it's like on the 2010>models though FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #286739 16th Oct 2014 12:26am
miggit
I don't get the trailer light, and having read the destructions there is no reference to the little green trailer, I will have to delve deeper into this. It does every thing that is listed, and I've had no problems, I wonder if its a plug'n'play thing, and the light gets enabled at the stealers. Did you have yours programed at the stealers or is it a plug'n'play? Yesterday I couldn't spell Engineer... Today I are one!
Post #286786 16th Oct 2014 9:08am
Mine, like most, was plug and play as I got the twbar a good two years before I got my faultmate. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #286787 16th Oct 2014 9:11am
mjdronfield
Sorry if I made things more confusing Paul, I don't think our early cars have the green tell tale, its the later ones I believe, like philmc79 has.
Never towed with an early one, but saw a mate with a later car, and his had it I'm sure.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #286797 16th Oct 2014 9:39am
miggit
Does that mean that I should stop looking for it? Confused I was beginning to think that it lived in the sump, because I couldn't find it any were else Laughing
So I have to look in the rear view mirror to see if I have a trailer on board then Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #287492 19th Oct 2014 10:12am
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Trailer. Warning light
Hi on 2006 model. There is a green light in dash panel that comes on when you plug trailer in just stays on to let you know trailer plug is attached. Earlier car the light flashed with indicators . Cars have. Landrover wiring kit fitted
Post #287940 21st Oct 2014 1:13pm
