Home > Maintenance & Mods (L322) > Engine blower running all the time? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
Have seen wires damaged at the viscous van hub, causing the fan to run on all time
12th Oct 2014 3:34pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
try pulling the fuse for a bit alan.. ... - .- -.
12th Oct 2014 3:36pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6719 |
Which one Stan? I can't see a number that refers to the engine fan Got - 2017 SDV8 Autobiography in Loire Blue
12th Oct 2014 3:48pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Is this the HVAC fan or the engine/radiator electric fan that keeps running? - if the former could be FSR related? .
12th Oct 2014 5:06pm |
It seems to coming from the big blower unit at the back of the engine bay, closest to the windscreen. It's not the fan at the front, and it vents out of the bonnet grill.
12th Oct 2014 5:10pm |
The interior blower still uses an FSR |
12th Oct 2014 6:06pm |
Can I pull a fuse to test and stop it flattening the battery? Got - 2017 SDV8 Autobiography in Loire Blue
12th Oct 2014 6:12pm |
i think its fuse 34 but not 100%... ... - .- -.
12th Oct 2014 6:22pm |
OK, its not engine related by the sound of things, either HVAC (in which case I reckon FSR) or possibly even FBH on the go?
12th Oct 2014 11:05pm |
Put the battery on charge last night and had a quick go at pulling out fuses 12 & 34, which I believe are both A/C related. Blowers still comes on as soon as the battery is connected.
13th Oct 2014 5:05am |
Got home tonight. Tried fuse 59, same problem.
13th Oct 2014 6:43pm |
Just a quick update to say the problem was indeed the FSR.
14th Oct 2014 6:01pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Present :2008 TDV8 HSE
14th Oct 2014 8:10pm |
14th Oct 2014 10:48pm |
