Home > In Car Electronics (L322) > Urgent help with GPS please, unable to reset arrow
verydisco
Hi gang
Special help for my friend whom has left his Range Rover Sport (same GPS system as 2005/2009 L322s) with me for a few days as he takes care of my own Rangie. I only have the Rangie for a few days hence the urge for your help to fix it.
The gps system acts funny and is completely lost.
I have tried to follow the owner’s manual how to reset it correctly (I did 5 times, even unplugged the battery for 10 min, etc.) but TILL, the pointer/arrow resets to the wrong direction (full East when it should be North West) right after the screen says the system has been reset successfully!
EDIT :
The location is correct, but the arrow goes full East and there is no vocal indication (road is hightlited though.
it simply says "please watch the map and indications will follow" BUT none do.
Anyone experience and corrected this?
TX
HERE:
THERE is a pic missing here where the arrow is Nothr West and I press "OK", then it goes to the next screen and the arrow is now back to full East Twisted Evil
EDIT
AS you may see, the arrow keeps on heading east while we cruise northbound.
 l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #285961 12th Oct 2014 8:14am
Does it keep pointing east when you drive, I find mine can be a bit errant on its initial direction assesment until you start moving, it then sorts itself out when it sees whch way the car is heading. There is nothing that can't be fixed with a hammer😜😜
Post #285964 12th Oct 2014 8:17am
Mikey
As above. After half a mile or so, it should get an accurate position/direction.
I know mine suffers from this issue occasionally. Just drive off and it sorts itself Thumbs Up
Post #285965 12th Oct 2014 8:19am
Its probably a faulty GPS Arial/Receiver they are prone to water damage. I have had a few need replacing in Jags mostly but a few RR. Easy job.
Post #285967 12th Oct 2014 8:34am
What gaz said if it has no idea where it is, but if it has got the correct location and it's just pointing in the wrong direction....... There is nothing that can't be fixed with a hammer😜😜
Post #285970 12th Oct 2014 8:53am
Is the car pointing east ? are you in head up or north up mode ? 2008 MY Supercharged
Post #285990 12th Oct 2014 10:32am
verydisco
Guys, sound Gaz nailed it as the car had a water damage after Land Rover dealership installed the snorkel and pinched the sunroof drain pipe.
Gaz, where would the said module/ ecu be located please? any tip on replacing it
much thanks l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #285996 12th Oct 2014 11:02am
Its normally the Arial itself located on the Roof.....
But could also be the wiring to the arial/connection.
Post #286002 12th Oct 2014 11:26am
verydisco
Thanks, will check the aerial and the wiring.
Anyone know if the roof lining needs to be take off completely to work on the wiring or simply popped-off on on side?
Also, the location is correct, but the arrow goes full East and there is no vocal indication (road is hightlited though.
Tx l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #286004 12th Oct 2014 11:44am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
not a problem to work on roof aerial with the lining in. just remove the clips for the dog guard and there is a plastic clamp a few inches into the roof from the rear in the centre.
Post #286149 12th Oct 2014 8:25pm
verydisco
thanks Wink l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #286168 12th Oct 2014 9:21pm
