Home > Maintenance & Mods (L322) > L322 - Westfalia detachable towbar from 2003 -fit my 2007MY? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
if you have a 2'' square hole and the the towbar has a 2'' bar , then yes it will fit. ... - .- -.
19th Sep 2010 4:43pm |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 |
according to the westfalia website, the bmw engined (<5/05) and the jaguar engined rr have 2 different part numbers so something is different but it dosent say what 2002 td6 vogue, 06 supercharged facelift
19th Sep 2010 4:47pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
Yes they work - I have just spent a week with a small Ivor Williams trailer hooked up to a 2003MY L322 drop plate hitch mounted to the 2003 Westphalia 2" attachment in a 2010MY 2" armature with no problems. The only difference is in the method of attaching the hook as I have both the 2003 and 2010 westphalia bike rack attachments and the newer version has a nut/bolt type securing whereas the old one has a pin with a second retaining spring pin to hold everything in place. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
19th Sep 2010 6:37pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Depends if you are talking about the armature or the ball bit.
19th Sep 2010 6:59pm |
NickH72 Member Since: 05 Mar 2010 Location: Surrey Posts: 92 |
It is the whole unit starting from having nothing fitted at the moment! still confused |
20th Sep 2010 10:59am |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
Hi NickH72 - I have also been looking for the entire Tow Bar kit to fit to my TDV8 via eBay.
20th Sep 2010 11:45am |
Not just that Delamo, the suspension also recognises that you have a trailer hooked on when you plug the electrics in and disables access height and also there is the little warning light trailer icon on the dash that checks the electrics are all OK which gets enabled - best left to the man with the enabling machine, either a dealer or if you have Autologic you can do it with that. Also if you have a 2010/2011 MY with LR Trailer Assist then that too may need to be enabled 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
20th Sep 2010 12:08pm |
absolutely Tim...
20th Sep 2010 12:14pm |
Got my armature from here:
20th Sep 2010 12:37pm |
LR Electics / control box of flea bay:
20th Sep 2010 12:47pm |
Can get one for £350 but they want another £300 to fit.. is it that complicated..??
20th Sep 2010 3:09pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3742 |
probably 3/4 of a day to fit it properly incl electrics and testing it. The rear bumper has to come off and all the parking sensors detached etc. Really its a 2 man job to fit the armature - unless you enjoy struggeling and are clever with a large trolley jack... |
20th Sep 2010 3:58pm |
Nick if you surf over to the Land Rover GTR (Global Technical Resources) website - there is a link from their main UK website you can download all the instructions for fitting all the accessories for free - you can see from them if you think you are up to doing the job yourself before committing to getting a dealer to do it, but I think you will still have to fork out £100 just to get them to hook your car up to their diagnostic system to enable the ECU for the trailer electrics (and loose the use of the car for a day!). Another person worth contacting in your part of the world is 10forcash over on the Disco3 forums - he's a self employed travelling engineer who services modern Land Rover at your house or office and also fits accessories. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
20th Sep 2010 4:00pm |
here are the westfalia specs, and right at the end the fitting instructions
20th Sep 2010 7:12pm |
