Home > Maintenance & Mods (L322) > l322 Front indicator Side Light Assembly Mount
Rextter
United Kingdom 2002 Range Rover HSE 4.4 V8 Barolo Black
Hi
I just picked up my 2002 L322 two days ago. It is the kind that has the separate headlight and side light/indicator module. I needed to replace side light/indicator on mine because the one on the driver's side had a big hole in it. The one I took off the car was held in with glue as the black plastic mounting bracket was broken.
I have searched for a replacement for the black plastic bracket but have not found any. Might anyone have a part number or is it a case of trying to repair the broken bracket I have?
Many thanks in anticipation.
Post #284941 7th Oct 2014 10:49pm
We can supply you the rear of a light with the mounting bracket intact for £75 + P&P... if of interest sir Bow down
Post #284942 7th Oct 2014 11:00pm
Rextter
Thank you very much for that Cam-Tech-Craig I will keep that in mind. Now I've had another look at the bracket I see it attaches to the headlight surround so quite a large job. I'll try to repair it with some epoxy resin first and see if that works. When I've taken off the large white plastic nut that holds the side light/indicator on I find they have glued it on the inside - ruining the thread.
Post #284963 8th Oct 2014 7:44am
idrawcad
United Kingdom 2003 Range Rover HSE 4.4 V8 Alveston Red
Hi Rextter, I had the same problem on mine. I bought a whole new LR assembly off the bay for £60 My Motto: If you are going to have one, have a BIG one!
Post #284966 8th Oct 2014 8:03am
I did a few "bodgit repairs" on mine, have a look:
http://www.fullfatrr.com/gallery/thumbnails.php?album=498 .
Post #284999 8th Oct 2014 9:55am
That's not a bodge Joe, that's "alternative engineering" Thumbs Up Pete
Post #285007 8th Oct 2014 10:21am
Laughing .
Post #285008 8th Oct 2014 10:24am
