Home > Wheels & Tyres > Are Evoke 20" wheels the same as L494 RRS 20"?
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
As the title suggests...
I have been looking for a set of L494 20" wheels (nicer than the L405 20" wheels). I have been told that these are strong enough to put on an L405.
I have seen lots of Evoke 20" wheels on fleabay that look identical to the L494 style I like. Are they strong enough to put on an L405?
Post #284843 7th Oct 2014 2:30pm
you'll need to get the specs for these wheels to be sure but i doubt whether they will take the weight of a FF.. ... - .- -.
Post #284857 7th Oct 2014 3:23pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
20" Epoke wheel no clear weight markings (Just checked) 45Off
although a 19" is clearly marked at 650kg Thumbs Up with a 45Off
Post #284863 7th Oct 2014 3:39pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Have had the same thought of putting the 20" Evoke wheels on an L322 so watching this thread with interest if anyone can confirm or deny the load rating of the Evoke wheels.
Thank 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #289695 30th Oct 2014 8:07am
verydisco
Evoque wheels only fits FL2 and vice versa.
L322's fit L405 & L494 and vice versa, in fact L320 Sport's do fit them also, but as mentioned above loads are different and should not be fitted to any L322/LR405/L494
hope this helps. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #289699 30th Oct 2014 8:37am
Evoque has the same wheel pattern as the FL2 so will NOT fit a RR of any type sir...
Model Year PCD Offset Bore
Defender 90/110 92 on 5×165 30 to 40
Discovery I 90 to 98 5×165 30 to 40
Discovery II 98 to 03 5×120 30 to 50 70.1
Discovery III 04 on 5×120 30 to 50 72.6
Freelander 97 to 05 5×114.3 35 to 38 64.1
Freelander II 06 on 5×108 35 to 50 63.4
Range Rover I 86 to 95 5×165 30 to 40
Range Rover II 94 to 02 5×120 30 to 50 70.1
Range Rover III 02 on 5×120 30 to 50 72.6
Range Rover Sport 05 on 5×120 30 to 50 72.6
Post #289721 30th Oct 2014 11:10am
160dmb
So just to be clear are we saying that the latest RRS (L494?) wheels will fit and carry enough weight for use on an L322?
Thanks 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #290228 2nd Nov 2014 10:29am
L494 wheels will definitely fit... Below are a set of Gen OE 494 wheels fitted to my Disco Thumbs Up
Weather the weight is right or wrong is up to your interpretation sir... i.e. replica wheels are less than half the weight rating of Genuine JLR wheels! But the L494 weighs considerably less than an L322 sir Bow down
Post #290261 2nd Nov 2014 1:07pm
160dmb
Thanks, for clarification I did mean to ask if genuine JLR L494 wheels were up to the job of carrying an L322, I wasn't going to go down the Chinese replica route. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #290370 3rd Nov 2014 12:22am
But many do sir, even fitted by main dealers!... Hence my comment about JLR wheels being VERY MUCH stronger than replica's which lots are happy to run Thumbs Up
I have run them on that Disco for a few years now 100% without issue and have sold several sets and have NOT had any issues at all Thumbs Up
Post #290373 3rd Nov 2014 12:31am
