Home > Technical (L322) > EAS problem
FTS999
England 2004 Range Rover Vogue 4.4 V8 Java Black
EAS problem
HI I carried out some work on the Valve block, to do this I jacked the car up on one side then drained the air out of the system. Now the work is complete it will only pressurise one side, the side that was jacked up. no air at all is going into the N/S springs that remained on the ground
Is this a possible defect in the block, or something due to the way i jacked it up perhaps. Thanks
Post #284063 2nd Oct 2014 9:37am
