Home > Maintenance & Mods (L322) > hopefully battery drain solved
pumper63
Wales 2002 Range Rover Vogue Td6 Zermatt Silver
have had a battery drain for a while now. not very technically minded Sad
but I left the side cover in boot off last night and locked the car.
went back 2 hrs later looked through side window and noticed that the red light on the sat nav in boot was still on Shocked
this is not right is it?
have pulled the fuse for now.
thanks in advance.
Post #283317 28th Sep 2014 12:58pm
mjdronfield
I believe it should shut down after a few mins....
Does the little red light near the gear lever stay lit also ? Though I'm pretty sure that may go out too.
Will check mine...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #283318 28th Sep 2014 1:13pm
pumper63
the red light near gearstick goes off after 20 mins, but it was a good 2hrs later that the red light in boot was still on Sad
thanks for your reply. Smile
Post #283319 28th Sep 2014 1:21pm
