Home > Technical (L322) > Hi and "Help my brakes are not working"!!
mzplcg
Sounds like the master cylinder to me. Had the same issue on a Ford Fiesta years ago. Thought I'd be a clever sod and bleed all 4 corners at once as we were changing the fluid. Opened all bleed screws, pipes in jars, all ready. Assistant mashed foot into the carpet and the pedal wouldn't come back up. Both front and rear seals in the MC were torn.
Probably done a similar thing with the pedal going down so far. They are delicate and tear easily when pushed beyond design limits. Ever since my experience I always use an Easi-Bleed and let the air pressure force clean fluid through. I never move the pedal whilst bleed screws are open now.
Post #283036 27th Sep 2014 8:15am
jfarrell32 wrote:
Great help thanks
Just trying to get an important safety notice across to any other members reading this. That starting a FF without sufficient brake fluid could easily & seriously damage the ABS pump/system let alone the SAFETY IMPLICATIONS of driving a 2.5t car on a public highway in FULL KNOWLEDGE the brakes were damaged!
As stated above by other members, without an amount of fluid in the system, you will rip the seals out and have absolutely NO/ZERO braking ability!!!
jfarrell32 wrote:
I'll stick that in the "I told you so" bucket.
Really!
Post #283045 27th Sep 2014 9:39am
jfarrell32
Ireland
[url]
Thanks. I will post the outcome (soon hopefully) in the hope it will assist someone on here in the future. Sounds like the Garage are trying to help but we will see. rgds john[/url]
Post #283070 27th Sep 2014 11:03am
Thanks Craig, I now know not to drive with no brakes. I will now fix my brakes before driving past the infant school. Thumbs Up
Post #283076 27th Sep 2014 12:17pm
ebajema
Mmmmmm the only time I was in a car with no brakes (a Citroen) we didn't get very far. Main reason the rear subframe with wheels and all came off ripping the hydraulic system apart. Thanks to the body of the car (and a lot of weight in it) dragging on the road surface we stopped pretty damn quick.
Now driving "without brakes" in an automatic seems virtually impossible to me as you would have a problem slowing or stopping. So lets conclude that driving without brakes is virtually impossible and that driving with "limited" brake capacity, especially knowing that it could fail completely at any point in time is irresponsible.
Having said that, I rode a bike (many many many years ago) that had too much air in the brakes and I had to "pump" up the pressure before stopping, now that is plain stupid/irresponsible.
So my point is, if the braking is insufficient to drive safely then don't. If the brakes are not "perfect" but you are sure you can stop quickly enough in an emergency situation, a carefull drive to a garage could be acceptable under certain circumstances IMHO.
I just did the front brakes on the Kawasaki ZX14 that I reassembled after 5 years in storage and had no problem with the brakes but I was very gentle in letting the system fill up by itself first before even touching the brake lever. I do regret not going for the braided brake lines (I have the originals on there still) because that would have made the braking less spongy. But it is in VERY good conditions still (well the bike only did some 6000 miles in one year and then went into storage for 7 years Smile). MY 2010 5.0 SC Galway green and sand interior!!
Post #283080 27th Sep 2014 12:49pm
Googsy
jfarrell32 wrote:
seals may have been damaged when the system was empty and I was driving it (only for a few kms to garage after discovering problem). Does this sound likely?
You drove it with a "split brake hose" Shocked really Exclamation
Do you guys not have recovery vehicles over there? I wouldn't even start the engine on a FF with a split brake hose... Let alone try driving it sir Shocked
Think we have a couple around somewhere Craig...... Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #283109 27th Sep 2014 3:54pm
jfarrell32
Ireland
Dear All, any input welcome.
Latest is that after many efforts to bleed the system the brakes are working. However there is travel in the pedal when you press for the first attempt to break. Mechanic has been testing and ABS etc all working but the travel is still a problem and is not correct. He has followed the process and has the technology to do this. He plans to drive it for this week and then try bleeding again after some use to try and correct the travel in the pedal. If this does not resolve it the last resort is to take out the master cylinder and check seals and possibly replace. He is still not convinced that it is a Master Cylinder problem. Any thoughts welcome - seems like a simple leak has turned into a painful problem.....
Post #283773 30th Sep 2014 2:29pm
IMO that would point to the master cylinder again..... Pete
Post #283785 30th Sep 2014 5:52pm
