Home > Wheels & Tyres > TPMS
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
TPMS
Hi,
Replacing 2 of my tyres is it necessary to renew the TPMS valves also ?
And if so what type do I get and where is the best place to buy them?
Thanks
Post #282900 26th Sep 2014 1:59am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Depends on how old ?
Most certainly replace the core
I always replace with Genuine
Also make sure the tyre agent is fully aware that TPMS is fitted it requires a slightly different method to minimise damage to the sensor
Post #282905 26th Sep 2014 6:00am
J evro
Thanks,
Anyone know if I take them in for the tyres to be fitted in Kwik fit etc they will have the TPM valves already there or do you need to take your own in ?
Post #282958 26th Sep 2014 1:31pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
They wont have new TPMS's. You will have to source and supply. You are then best calling to ask if they will fit them before booking in as they may not.
Not 100%, but think they have to be coded in to the car so it may be worth just getting it done as a whole job at an Indie.
Others will correct me if i'm wrong.
Personally, I had all mine removed and standard valves fitted, then turned the TPMS off using the IID tool. I think they are a liability IMHO.
Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #282959 26th Sep 2014 1:41pm
J evro
Thanks Paul,
I don't seem to be able to find an indie around my area down Near Canterbury in Kent sure there must be one about somewhere,
So kwikfit etc would/could just fit normal valves at my request then yes ?
Post #282960 26th Sep 2014 1:55pm
paulmoran2
Would have thought so, but just ask before booking in.....
Then you have to turn TPMS off, otherwise you'll have a warning indicated.
P GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #282961 26th Sep 2014 1:58pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I replaced my TMPS valves last year
You will need to source replacement TMPS valves before going to get new tyres - they certainly won't stock them
About £50 each from a LR dealer or £50 for a set of four on eBay - make sure they come with the nuts, these are not re-usable from the old valves
The new TMPS valves will recode themselves to the car within about 10 mins of driving
If you fit a new TMPS in the spare, you either need it coded to the car using diagnostics or put the spare on and drive for 10 mins
Hope that helps - I am considering getting mine turned off next time I get my car serviced as the system only works about 60% of the time Censored (note a LR dealer will not do this, you need an Indy - apparently they won't do it for safety reasons even though LR sold RR's without TMPS Whistle ) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #282986 26th Sep 2014 7:06pm
J evro
Thanks Gents,
Anyone have a link to the correct ones with nuts etc required from eBay or similar
I've looked and there are quite a few different ones and I haven't a clue tbh
Thinking if I'm changing tyres I may as well change these whilst I'm at it
Post #283026 26th Sep 2014 11:02pm
ken
Hope this helps Larger to the right OEM L322 Left L405 both transmit on same htz Thumbs Up
Post #283082 27th Sep 2014 12:50pm
J evro
Anyone know what MHz ones I should opt for to pair up with my vehicle?
Post #283100 27th Sep 2014 2:08pm
ken
You need the ones on the left however a simple call to a Dealer will confirm and not once have I ever had to code a spare on a L322
Post #283116 27th Sep 2014 3:51pm
J evro
Thanks, however I was thinking of going non OEM type that is where my confusion in which ones to choose comes in Thumbs Up
Post #283121 27th Sep 2014 4:15pm
ken
Then your on your own
Places like tyrebay direct sell kits but its really unchartered territory at present
Non gen replacements will in-time become common place but i feel just a little to early
Theres plenty of aftermarket full kits but oem mimic ones are not that easy to come by
Post #283132 27th Sep 2014 5:17pm
J evro
Well got the new tyres on and the fitter tells me the valves are pretty new so all good Very Happy
TPMS light lit up but extinguished after driving 6 miles down the road Very Happy
Decided I do need new wheels though ?
Post #283983 1st Oct 2014 7:09pm
