Home > Technical (L322) > Air Suspension Question
FTS999
England 2004 Range Rover Vogue 4.4 V8 Java Black
Hello everybody, Hope you can help, I have a RR Vogue L322 2004 which has suffered some air suspension problems. My local RR Dealers said the compressor was at fault so I fitted a new Wabbco compressor. It want back to RR and the said the Ecu was confused So they fitted a new Ecu which has sorted out some of the issues but Im left with one problem, RR have told me the system has been calibrated but the F/N/S keeps on inflating to the extent it could blow the airbag.
They now suspect its the valve block, another £650 any ideas Please.
Post #282547 23rd Sep 2014 7:40pm
could the height sensor be faulty perhaps? ... - .- -.
Post #282553 23rd Sep 2014 7:54pm
FTS999
I will look into this thanks
Post #282697 24th Sep 2014 9:02pm
mzplcg
OK, I'm not sure about the L322 but I do know the Disco 3 had to have a new revision of the software loaded to go with the new version of the compressor so that's a possibility as well. The new compressors run at 9 bar instead of the original 11 bar.
More importantly I would be very wary of any garage who troubleshoot by swapping parts out. That's basically guesswork and you're funding it.
Post #282722 25th Sep 2014 4:12am
