Home > Technical (L322) > What are these sockets for
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Doing a little work in the engine bay today and came across these two sockets. I have no idea what they are for or if they should be connected anywhere.
As you can see from the pix they are by the the diesel filter.
Hope someone can shed some light on this. Bow down Thumbs Up
Post #282319 22nd Sep 2014 8:48pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
dont qoute me but believe in hot countries theres a fan and thermostat fitted to the front of the fuel cooler. thats what the 2 plugs are for.
Post #282320 22nd Sep 2014 8:59pm
Pretty sure that is the fuel/diesel filter 😜 There is nothing that can't be fixed with a hammer😜😜
Post #282321 22nd Sep 2014 9:06pm
iphs
Your right. sorry typing faster than I can think. Rolling Eyes
Post #282322 22nd Sep 2014 9:09pm
mjdronfield
Both of them ?
Will have to check in rave. The rectangular plug is def for the fan for the fuel cooler as mentioned above but I thought that was the only connection it had. Could be wrong.......
Will check mine later....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #282359 23rd Sep 2014 6:12am
Sandyt
Might be for the deep fat frier that you trattor boys like Laughing
Post #282373 23rd Sep 2014 7:44am
mjdronfield
Laughing
Feed for the noise cancelling headphones 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #282383 23rd Sep 2014 7:56am
mjdronfield
Here is the wiring diagram in RAVE ;
If the 2 connectors look like they may be joined by a single wire, one is for the fan motor and the other the temp switch....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #282424 23rd Sep 2014 11:57am
mjdronfield
Just had a look at mine and I indeed have the same 2 unused connectors.
Must both be used for the fuel cooling in warmer climates then....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #282455 23rd Sep 2014 3:18pm
iphs
I Thank you Sir.
BTW I'm not a Norfolk man, I am a Yorkshireman. So I shall use the power source for my yorky puddin maker. Thumbs Up
Post #282473 23rd Sep 2014 4:25pm
