![]() | Home > Technical (L322) > Aarrgghhh |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
But then once you get to the bottom of this it will be another area you are an expert in |
Dave ray Member Since: 19 Sep 2011 Location: Wirral Posts: 92 ![]() ![]() ![]() |
I was hoping for a bit of advice |
http://www.fullfatrr.com/forum/topic24878....suspension
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
If the suspension has locked out, e.g. light on normal and light on in centre of button, or no lights at all, you will need a diagnostic tool to reset, read the fault codes, investigate and repair. Once you know where the fault is coming from you can do something about it.
