Home > Maintenance & Mods (L322) > Jacking up with electric side steps
Front.
Rear.
Post #282003 20th Sep 2014 3:44pm
Under the bottom ball joint on the front suspension arm, if you really can't find anywhere better.
Or get a large bottle jack and use the proper jacking points, which would be better and safer Adam, not good if the suspension decides to level itself out whilst you have a jack under it, so make sure you leave a door open. There is nothing that can't be fixed with a hammer😜😜
Post #282006 20th Sep 2014 5:58pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Unnecessary quote removed
Excellent thanks
Post #282010 20th Sep 2014 6:59pm
Bottle Jack Modification to replace Scissor Jack
Post #282012 20th Sep 2014 7:10pm
Don't be tempted by the 4 tonne halfords jack, doesn't lift high enough.
Merc sprinter jack supposed to be best way forward, not used one however as I use a high lift 4x4 trolley from machine mart cos I don't have steps, it will fit under, fit under the tubes as well. it has an adjustable head on it so it gives a bit more lift and can be wound up almost to touch the jacking point before you start pumping.
This one.
https://www.machinemart.co.uk/shop/product...ley%20jack There is nothing that can't be fixed with a hammer😜😜
Post #282014 20th Sep 2014 7:35pm
J evro
Yeah got a trolley jack but thinking the bottle jack will be more suitable to always have in the vehicle....... They're £39.99 now though , typical
Post #282034 20th Sep 2014 9:19pm
