Home > Maintenance & Mods (L322) > Side Steps - Sheared bolts... Help! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Unfortunately not, the plastic covers the sill which is a box section so no access to the captive nuts
15th Sep 2014 10:11am |
Jumpy Member Since: 23 Aug 2014 Location: Surrey Posts: 14 |
Thanks for answering my question.
15th Sep 2014 10:23am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Nightmare! Sounds like it may have had side steps in the past, and removed the quick way! You may have to remove the air reservoir on the RHS if you have the same problem there. If tapping out a new thread is an issue, you could try rivnuts? .
15th Sep 2014 4:58pm |
15th Sep 2014 5:20pm |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 |
If you have a welder you have 2 more options
15th Sep 2014 7:42pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
staying simple and cheap, start here,
15th Sep 2014 10:09pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
The last set we had like this. We cut the top off the step, (where the existing bolt holes were) drilled two holes in the step upright and simply made another top (upright section) wider than the original and used rivnuts either side of where the snapped nuts were
15th Sep 2014 11:23pm |
Craig - I must say I like your use of the word "simply" !! Surprised your note doesn't end "all that and we still made it home for tea" !!!??
16th Sep 2014 4:45pm |
16th Sep 2014 5:56pm |
