Home > Technical (L322) > How to fix One Touch window closure
When you remove your battery, or disconnect etc, you can find certain things have been wiped from the car.
If the window closure one touch feature is gone there's a quick fix that doesn't require a Dealer or an IID tool.
Open the window and keep the button pressed all the way down, then reverse it all the way up and hold for a few seconds. This should reset the feature to close on one touch. Discovery 4 HSE
Post #280543 12th Sep 2014 10:53am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
That's handy to know Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #280545 12th Sep 2014 11:08am
gav
United Kingdom 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
awesome! I'm off to try this. Thumbs Up
Post #280596 12th Sep 2014 5:51pm
Handy tip, works on most cars and also works on the sunroof... Pete
Post #280612 12th Sep 2014 6:24pm
gav
Didn't solve mine.... Confused Rear passenger window will not go up with one touch, although goes down with one touch.
Post #280613 12th Sep 2014 6:26pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Only works with the engine running.
Ian
Post #280706 13th Sep 2014 9:25am
Adam, its pretty much the same as doing a lock to lock with the steering when reconnecting the battery so the steering angle sensor knows its perimeters... It shows the window motor its perimeters too Thumbs Up
Post #280714 13th Sep 2014 11:02am
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
can you turn if off easy? I find opening window in rear for dogs a pita it either tries to keep opening or keep closing. It becomes a delicate game of how light and fast can you flick the switch Laughing 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #280727 13th Sep 2014 12:47pm
^the switch should have a 2 stage action, around half way pressed there is a stop, press it past this and it auto opens the rest of the way. There is nothing that can't be fixed with a hammer😜😜
Post #280737 13th Sep 2014 2:18pm
The one touch function can be switched off via the CCF files too Thumbs Up
Post #280832 13th Sep 2014 9:39pm
