![]() | Home > Technical (L322) > Head light levelling |
Chances are no headlight leveling ecu is fitted to your car according to RAVE as follows.
Liszton3 Member Since: 27 Feb 2012 Location: UK Posts: 2 ![]() ![]() |
Thank you!
Might be worth reading this as well before you go back. From the MOT inspection manual.
gav Member Since: 03 Jan 2014 Location: Hertfordshire Posts: 37 ![]() ![]() ![]() |
Somewhat related.... My levelling unit got wet and corroded and killed the k-bus. My Indy has replaced it with a used one from a td6 and can't reprogram it to petrol with his auto logic system.
AFAIK the mileage is logged in three different ECUs and if you replace any of them, the black dot will appear on your odometer to indicate a discrepancy between the 3 ECUs in mileage. The systems should still work since ECUs can fail and need to be replaced without "stopping the entire vehicle from working". |
Am I missing something here ? Unless your car has adaptive headlights there is no levelling unit to fail, the suspension levelling fulfils that function and you shouldn't have failed the MOT in the first place . 2008 MY Supercharged
Plus one for Axle |
On the earlier cars, in addition to the air suspension self leveling, there was a self leveling system on each xenon headlight which operated thro a small motors and screw-drives controlled by an ecu. This leveling system operated continuously when the car was driven, small adjustments being made as the car drove along.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
I totally agree... In 2004 the system was binned and a system that worked was not introduced until 2005/06 on the facelift |
Thanks Craig.
