Home > General > ciggy lighter socket
i've brought a gps speed camera alert thingy and i would like to use either the ciggy socket by the gearshift or the one in the cuby box but, i'd like the alert thingy to go of with the ignition..do any of these sockets do that or if not any ideas... ... - .- -.
Post #28026 14th Sep 2010 3:02pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
The one by the gearstick turns off with the ignition. Depending on year you then get cubbybox and boot live for ever, or cubby box and boot live for 10 mins with car open and OFF if locked, or no power at all when ignition off.....fun eh? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #28027 14th Sep 2010 3:13pm
the one i what to use [cubby ] is still live when the ignition is off, are you saying that there is a ten minute duration before it goes off. ... - .- -.
Post #28028 14th Sep 2010 3:21pm
DMRR
There is on my 2010 - I don't think there is on the touch-screen pre-2010. Like I say, at least 3 different "setups", my first was ALL OFF with no key. My second (2006) was boot and cubby LIVE at all times, and this one 2010, is cubby/boot on for 10 mins unless car locked - then no power.
There is some mention of it in the handbook as I recall, for at least the touchscreen and the 2010. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #28029 14th Sep 2010 3:47pm
thanks thrasher, i'll have to do the obvious thing and plug something in and wait to see what happens.. ... - .- -.
Post #28030 14th Sep 2010 4:04pm
Vogue
if you have the large type cup holder, pull it smartly up. You will find underneath it several live feeds. On my old FFRR I fitted my Radar Detector to one of these with a scotchlock so that it goes off with the ignition. Might need to mess about with a bulb holder on a couple of wires till you find a power source that goes off with the ignition.
I posted on this on an earlier thread - might turn it up if you do a search on power source or speed detectors etc.
Post #28037 14th Sep 2010 4:57pm
Vogue
here you go :-
http://www.fullfatrr.com/forum/topic608.html?highlight=cable
Post #28038 14th Sep 2010 4:59pm
cheers vogue..my 'hole' had a 'big ciggy container' in it , is that what you mean. ... - .- -.
Post #28040 14th Sep 2010 6:17pm
Vogue
yes thats it, lift out the ash tray, and you are left with a cup holder, just grab hold of it and pull it up and out smartly
Post #28083 15th Sep 2010 9:40am
i'll try and do that today vogue.. Thumbs Up ... - .- -.
Post #28087 15th Sep 2010 10:36am
found the wiring underneath the cup holder vogue thanks.
@thrasher , the socket by the gear shift stays live even when key out and car locked ..is there a delay on this one.. ... - .- -.
Post #28258 17th Sep 2010 9:50am
dan_uk_1984
2003 - Cubby box & boot live at all times.
Post #28269 17th Sep 2010 11:48am
that's the same with my 2005, and it looks like the gearshift one is as well. ... - .- -.
Post #28277 17th Sep 2010 12:03pm
Vogue
it wasn't on my old 06 face lift as that definitely used to go off with the ignition - had to otheriwse my plod detector would have been on all the time.
Post #28286 17th Sep 2010 12:18pm
