Home > General > I've got a fridge !
fisha
There is a small hole connecting the air con vent pipes running to the rear seats and the centre cubby box. So if you have the rear vents set to cold, it'll blow chilled air into the cubby box. It's just a trickle of air, but works well. V8 or else ...
Post #279652 7th Sep 2014 8:57pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
So it does , I always had the rear vents off as haven't carried anyone in the rear yet
Glad I found out after 2 weeks Rolling with laughter
Post #279737 8th Sep 2014 1:58pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Fridge???
The sports came with what could be a called a fridge on the cubby box, even white and all....
The FF, only has the option of the extra cooling pack which connects to the power source.
But....
If you activate the rear vent controls (bottom right button on the center console) and power the fans to at least 50%, with the air running cold, on a hot day you can really feel the cubby box getting very cold.
Same happens on winter, get it hot and you can warm up what's inside the cubby box
Post #279756 8th Sep 2014 5:07pm
J evro
It works really well actually Thumbs Up
Post #280098 10th Sep 2014 12:49am
OK - so it's not a real fridge - but it is perfect for getting a can of coke to the ideal drinking temperature Thumbs Up
Post #280242 10th Sep 2014 7:13pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
excellent, thank you guys
Post #282387 23rd Sep 2014 8:10am
