Home > Technical (L322) > Annoying Radio
stefME13
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zermatt Silver
Annoying Radio
Hi Guys. Just got my 2003 vogue today and I've got an annoying problem with the radio! It's like something's pulsing through the speakers or an easier way to explain it would be to say it sounds like someone's turning the volume up and down every 5 seconds. I've had a quick play with settings but no joy. Has anyone come across a similar problem or got any ideas? Sad Thanks in advance
Stef..
Post #27517 8th Sep 2010 6:56pm
dan_uk_1984
Do you have an aftermarket phone kit installed or anything else that's non standard?
The next bet if everything is standard is to get some contact cleaner and spray all the plugs into the various audio equipment in the boot (left hand side) Whilst you're there, check for water leaks as these play havoc with the audio system.
Dan
Post #27535 8th Sep 2010 9:22pm
stefME13
Hi Dan, Thanks for that. It does have an aftermarket Rear Entertainment system DVD/PS2 Which I can't get to work properly. I'm a bit of a numb nuts when it comes to anything electrical so I'll have to get it looked at. Can anyone recommend someone in South East Kent?
Post #27542 9th Sep 2010 5:44am
stefME13
Post #27543 9th Sep 2010 5:45am
I finde my radio incredibly annoying but if I turn Chris Evans off it gets much better. 2008 MY Supercharged
Post #27545 9th Sep 2010 6:20am
stefME13
Chris is OK! But one minute he's shouting and then the next whispering!! lol
Post #27546 9th Sep 2010 6:26am
iT LAD
Laughing Laughing
Post #27554 9th Sep 2010 8:11am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi Stef, I'm going to go for a more basic answer just on the off chance. If your volume goes up and down, is it when you speed up and slow down and does it also occur on the CD player etc? If it does, it's most likely the AVC (Automatic volume control) is set too high so that small increases in speed cause the volume to go up noticeably (and vice-versa). I have the touch screen but assume pre-touch etc have the AVC somewhere and I set it a bit too high once and as I say went onto a motorway slip road, the volume ramped up too much, so I turned the sensitivity down. Just a thought. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #27990 13th Sep 2010 3:49pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Not noticed AVC on my 2003 but maybe I've not looked hard enough.
CVC would be a real bonus where the first C=child 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #28015 14th Sep 2010 12:22am
stefME13
Update to annoying radio!!! Hi all after being without my ffrr for 5 weeks now, yes that's right 5 weeks. The dealer has finally come up with the fix!!! The car went into Land Rover for a diagnosis and the sat nav unit was found to be faulty, the part was ordered and fitted in under a week but didn't solve the problem with the radio.
I was then told that they needed to replace an ecu but weren't able to source one in the UK so had to order one from BMW Germany. This part took a little longer just under 3 weeks to arrive and fit! Bow down But hey you guessed it still hadn't fixed the radio.
After getting in a Land Rover audio specialist, not sure that's his full title, it turns out that they now need to order new keys from Germany and pair them too the new ecu. The pulsing is coming from the immobiliser and have been guaranteed that once the new keys arrive and are paired up this will solve the annoying radio problem! Fingers crossed lets hope so!!
As soon as I get her back I'll be sure to post plenty of pics Thumbs Up
On the plus side I'm not picking up the bill Razz
Post #35889 12th Nov 2010 12:16pm
mzplcg
That's called the Rear Seat Entertainment option Thumbs Up
Post #35908 12th Nov 2010 3:03pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I had something odd the other day where the volume kept rising on its own - nothing to do with speed, just getting louder. Happened one time and hasn't come back.
Post #35920 12th Nov 2010 4:36pm
