![]() | Home > Technical (L322) > Diesel refueling issue |
GrahamCharlton Member Since: 17 Aug 2014 Location: Newcastle upon Tyne Posts: 30 ![]() ![]() ![]() |
I have the same issue with my 2011 TDV8. There's lots of talk on here about a yellow flap that prevents you filling the tank with petrol by mistake but in my case it simply seems like the filler neck is too narrow I've only had the car a couple of weeks so have only filled it once so will have a closer look the next time I fill up. |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Graham
Turn the nozzle upside down and try ![]() |
Stop using the commercial diseesel pump |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
Nope not in mine. I don't believe I have the wrong fuel device fitted. I can't see anything yellow down there. Just seems like the filler neck is to narrow |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2662 ![]() ![]() |
Like sex, you just have to give it wiggle & ram it in, if you're too gentle it just doesn't go in!! |
I'll go have a look |
Here you go:
Yup, thats what I got. I will take your advice and give the gun a good shove next time.
I hold the pump at 90 degrees to get it in |
I will give it a little wriggle as well |
