Home > Technical (L322) > 4.4 V8 gearbox issue (04)
Page 1 of 3 123>
Lenb
England 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi Folks,
Really was hoping I wouldn't have a problem so soon!!! Anyway, towing my caravan today, (good test for it just 2 days after buying), after about 30 miles, the gearbox suddenly changed down to 3rd and would not change back up. This happened at 50 mph and slowing down to about 35mph it changed down to 2nd. It would go back into 3rd but only after booting to about 4,000 rpm. The only way to clear it was to switch off and restart after 2-3 mins. I would then drive another 10 miles and it happens again. On my 80 mile journey this happened about 6 times. It is going back to the garage but I've yet to go home. It was as if it was in manual - but wasn't. Trying in manual didn't help.
Any ideas would be welcome.
Regards
Lenb Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Previous: 2000 P38 DHSE - 1995 P38 DT Man - 1990 3.9 SE Classic, 1980 3.5 Classic 2dr
Post #279463 6th Sep 2014 6:09pm
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
That is a protective mode for when it is running too hot. Some sort of cooling issue I'm afraid.
MC
Post #279475 6th Sep 2014 7:02pm
Lenb
Cooling issue
I did wonder! And it does smell hot even though temp gauge Normal. No error showing on message centre and also it does 'judder' as though going over a grid occasionally. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #279476 6th Sep 2014 7:06pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I may be talking out of my ar5e but could be a gearbox intercooler, colleague with an X5 had that same issue Thumbs Up
Post #279477 6th Sep 2014 7:24pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
It's the gearbox temperature rather than the coolant temperature so coolant may well appear as normal on the gauge. When the gearbox detects over temperature it will hold onto higher revs in each gear in order to pump more oil through the cooling system to aid cooling.
It could be an issue with the normal coolant system though as it uses the coolant in a gearbox oil cooler as a heat exchanger, the bottom 6 or so cores of the radiator supply the oil cooler and if they get clogged/silted up then oil cooling will be affected.
Likewise the oil cooler itself could also be clogged up.
Cattle grid like judder below about 55mph is an indication of a worn lock up clutch in the Torque Convertor.
Post #279478 6th Sep 2014 7:37pm
Mistercorn
Mine did both of those things. �I ended up spending about �1800 on a full rebuild.
MC
Post #279480 6th Sep 2014 7:39pm
kiter
Had similar problem last year when towing - changed the gear box filter and replaced fluids and also put a new radiator in her, mine has done over 150k on the clock - did same journey this year with caravan and no issues at all. Did a 300 mile round trip this week with a car transporter and VW Golf on it - towed it brilliantly.
Post #279487 6th Sep 2014 8:05pm
Lenb
Kiter
That sounds a bit more promising! I have an 80 mile journey home on Monday so will have to take my time. It's going back to the garage I bought it from as soon as I get back. I'll show him these posts. He seems a decent guy so hopefully it'll get sorted. (Got an even longer journey Oct with caravan so it had better get sorted!!!) Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #279489 6th Sep 2014 8:20pm
Mistercorn
Make sure you demonstrate the cattle grid issue. It is a gearbox out job.
MC
Post #279490 6th Sep 2014 8:27pm
johnboyairey
my previous owner had a full gearbox rebuild, as was (gearbox) overheating and had done the little cooling rad at the front under the water rad already, it turned out (after rebuild,) to be the fluid pipe to (or) from the cooler was partially blocked, and required replacement. the rubber hose can collapse internally, causing a block. that was after �2500 gearbox work. you could disconnect/remove these and blow (mouth) air through them? (with clean tubing attached)
first thing to do, Is a fluid/filter change though.
the main reason I bought my 2002 v8 was that it had already had the gearbox done, as its one of those top 10 things to watch for, and sort of the hardest to do cheaply.
Post #279520 6th Sep 2014 11:09pm
Lenb
I did ask the dealer if he had done an oil change on the gearbox - to which his answer was "yes'. However I will get him to do it again. I also own a P38 so know how important this is!!
All this information is very helpful and much appreciated!! Smile Thanks everyone!! Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #279522 6th Sep 2014 11:18pm
Lenb
Update + question:
Gearbox oil and filter changed, codes read (nothing), flow test on oil cooler and ok. I will now do a tow test to see if it happens again.
However: The mechanic suggested that because I was towing at 50 mph (the legal limit on single carriageways) the gearbox would not lockup (which is 56mph) causing more heat. Does this mean I will always have this problem? Any thoughts on this appreciated. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Post #280263 10th Sep 2014 9:42pm
kiter
I will probably regret saying this but........... since doing the filters/fluids and radiator on mine the problem has never re appeared - last trip with the tin tent was from Inverness to Oban so not a great road with lots of slowing down/pulling away again and dont think I ever got much over 50mph, no issues at all - tin tent is a twin axle hobby at probably just over 2 tonne with all the gear.
Post #280272 10th Sep 2014 10:24pm
johnboyairey
try reading up some more on how to 'hear' the torque converter 'lock-up'. (easier on a diesel for obvious reasons) it is sort of like, you just stopped resting your foot 'on the clutch' and you take it off, to feel the car, sort of heave forward, and pedal gives a bit more 'grunt' or 'feel' -revs decrease a little etc. you can overcome this problem at 50mph, by using manual mode with the gearbox. you can then, on single carriagways, hold 3rd gear, (or any forward gear) allowing 'lock-up' in say, 3rd at a slower speed. This will prevent premature wear on box, and give you drivabilty. you can pull it down a 'cog' with the gearstick, or drop it to 'D' at anytime, read the manual. i use this (manualmode) when driving with a trailer behind lorries on an incline.
basically at a certain speed, your gearbox stops 'slipping' and locks drive from engine to propshaft. if you kickdown, or labour engine, it will drop from lock-up to slipping/slushing again.
with some practice, you can get car to lock-up, and you resume driving very slightly slower, (still locked)
Post #280367 11th Sep 2014 11:06am
If the gearbox is fine, there is no reason why you should have to worry about the lock up....
It should tow it's maximum weight all day long at 30mph, or any other speed, with no issues
If it still does it then there is something wrong....
Did he use the correct gearbox oil as it's very important to use the correct stuff??
My money is on the rad, gearbox oil cooler and lines.... Pete
Post #280375 11th Sep 2014 11:55am
Page 1 of 3 123>
