Home > Maintenance & Mods (L322) > Bonnet stay release or not? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6361 |
In order to swap out the battery do you need to undo the two hydraulic stays for the bonnet to open it further?
6th Sep 2014 11:02am |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
Allows bonnet to go vertical , so much better access.
6th Sep 2014 11:44am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3217 |
6th Sep 2014 11:45am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
in the wiki ... - .- -.
6th Sep 2014 11:47am |
Are the spring clips on the top or bottom part of the telescopic arm? ie attached to the bonnet or the wing end? Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
6th Sep 2014 1:41pm |
On my 2006 I put the new 100 Ah in without removing the struts, tight but doable. MY 2010 5.0 SC Galway green and sand interior!!
6th Sep 2014 2:37pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Both!
6th Sep 2014 2:38pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Unclip at the bottom of the struts but don't take the clips off just leaver them down a bit until they release then you don't have to spend the rest of the afternoon on your hands and knees looking for the one that flew off some where 2008 MY Supercharged
7th Sep 2014 3:50am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Adam, lever out the lower clip by around 2mm then pull the lower ball socket apart... Then when its off, push the clip back into its original place (so when you push the ram back on, it automatically locks back on) IMPORTANT POINT! Put the end of the ram you have just removed UNDER the corner of the under bonnet sound proofing carpet. (That way, when you lower the bonnet to re-fit the gas struts they DON'T SCRATCH the front wings!!!) Do the other side the same, then secure the bonnet in the upright position using BOTH of the clip sliders! (your bonnet is aluminium and will warp VERY VERY EASILY!!! Just takes a gust of wind!)
7th Sep 2014 9:22am |
Great tips guys, thanks, especially Craig Discovery 4 HSE
7th Sep 2014 10:59am |
