Home > In Car Electronics (L322) > Blank Screen
Kiwi_V8
New Zealand 2004 Range Rover Vogue 4.4 V8 Java Black
Blank Screen
I've got a 2004 Vogue with non-touchscreen satnav.
I bought a new MK4 DVD nav system. While I was waiting for the new system I removed the old MK3 to get it up for sale, waiting for it to power down before removal. I drove around with no nav unit installed and predictably there was no screen in this state.
The new system has arrived, I plugged it in and I still have a blank screen.
A quick read on here and the concensus was that these faults are due to a faulty nav unit, so I plugged my old mk3 back in and the screen is still blank.
I checked all the other connectors on the other boxes in the back there, they seem ok. Is there a fuse I need to check? I find it doubtfull that there is one fuse just for the screen, but not head unit as that is working ie still plays cds and the radio is working. I just can't see anything on the display.
I guess I've deeply offended the electronics on my FFRR by treating it with such disregard, any idea how I go about getting it back onside? I doubt that both units are dead and there is no dampness in the rear compartment.
Post #279072 4th Sep 2014 4:05pm
mjdronfield
When I swapped my TV unit for a hybrid one, I got a green type display when the connection wasn't good, so I'd imagine you have a good connection, but no power up.
When I changed nav units, I just did a straight swap without powering on in between, so didn't have this issue.
I wonder if the nav unit has to be seen on the ibus again since it's been off for so long. I believe all the units daisy chain through the nav.
Mmmmmm strange.
Someone will say disconnect battery for a bit, which may work, but it's a long shot IMHO. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #279075 4th Sep 2014 4:32pm
Kiwi_V8
Yeah, I think running around with the satnav unplugged may have upset it, might pull the battery leads off for a bit and see if that tricks it back to life.
There is power to the screen as you can see a slight change in colour on the screen when the key is inserted into the ignition..
Post #279076 4th Sep 2014 4:35pm
mjdronfield
I've just put BMW blank screen into google, as it's the same system, as you know, and they seem to say disconnect battery to reset it or it's a faulty nav unit, as that processes the video.
As both do it, are you sure you've not disturbed another connector whilst doing the work ?
I take it the nav unit powers up ok ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279078 4th Sep 2014 4:43pm
mjdronfield
Is this any use ?
http://www.m3forum.net/m3forum/showthread.php?t=247929
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279079 4th Sep 2014 4:47pm
Kiwi_V8
I tried pulling fuse 49 for 1/2 an hour. I'll try pulling the battery tomorrow.
I cleaned up all the connectors on the TV box, no joy.
Don't think I knocked any of the connectors when I pulled it out.
Should the screen still have worked with the unit unplugged?
I'm cruising out to Duckworths tomorrow, I'll have a chat if I get no joy with the battery reset.
Post #279110 4th Sep 2014 8:09pm
mjdronfield
I've not tried with the unit unplugged, but I believe the nav sends the video to the front end, so I'd imagine it won't work without the nav.
Did it work when you had the unit removed ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279112 4th Sep 2014 8:15pm
Kiwi_V8
Everything worked apart from the screen and the nav of course..
Post #279113 4th Sep 2014 8:19pm
mjdronfield
Do you get the red light on the nav unit ? In the boot ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279114 4th Sep 2014 8:23pm
Kiwi_V8
Yes, the red light comes on and you can hear the disc spinning away, so that seems ok.
Might also try loading a fresh v32 software disc.
Post #279116 4th Sep 2014 8:46pm
mjdronfield
Mine has the standard v32 software loaded, I understand some modded ones with speed cameras and 7 digit postcodes can cause issues.
Doesn't explain why it won't work with your old mk3 unit though.
I'd disconnect the battery for a bit and see if that helps like the BMW chaps have done. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279118 4th Sep 2014 8:52pm
Kiwi_V8
Have to admit, it's got me a bit baffled, I really did expect it would burst back into life when I plugged the original unit back in. There is a link on that site describing how reloading the firmware managed to recover the system.
Not particularly keen on trying the firmware update if I can't monitor it booting up, but if the battery disconnect doesn't work I don't think I'm left with many options.
Post #279120 4th Sep 2014 9:01pm
mjdronfield
Get it working with the old mk3 unit if you still have it. That's a known working unit.
Then swap without powering the car up inbetween.
Worth a try if batt disconnect is no good. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279132 4th Sep 2014 10:03pm
Kiwi_V8
OK, so I tried the software update on the new unit after having unplugged the battery for 20 minutes, no joy.
So I took the blue lead off the TV unit and plugged that in and hey presto, all was good with the world.
The issue appears to be with the blue connector on the back of the Nav unit, I'll fire some contact cleaner into that and see how I go, fingers crossed..
Post #279211 5th Sep 2014 12:25pm
mjdronfield
A step in the right direction is always good.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279252 5th Sep 2014 3:59pm
