Home > Technical (L322) > Shot a spark plug |
Never even heard about this on other cars (not saying it can't happen). Could be that someone overtightened the spark plug and stripped the thread. MY 2010 5.0 SC Galway green and sand interior!!
3rd Sep 2014 2:26pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
It's not happened to my diesel. |
3rd Sep 2014 2:28pm |
RugbyXV Member Since: 14 Feb 2013 Location: Rugby Posts: 42 |
I had it happen in my MGF a few years ago, helicoil sorted it and it's still going fine today...I must just a be an unlucky car owner!! Owning a Range Rover is the land based version of a boat...a hole in the road in which to throw regular bundles of money! |
3rd Sep 2014 2:37pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
i had that happen many years ago, on a triumph with an alloy head. in those days of budget bodges it was a case of sawing a couple of grooves into the thread of another spark plug, and carefully using it to tap a thread as the last two or so coils in the head had stripped, but they were what you need to guide the plug in, having nothing to lose, and plenty of gease to stop swarf dropping in, it went in fine. changed for another and presto. they can unscrew over a long period if not properly tightened, and that's easy to misjudge, with a UJ extension. I believe you can buy a 14mm tap to rethread the holes of popular plugs. they are nice and long, so you get them in at correct angle.
3rd Sep 2014 2:41pm |
Got to be worth £20 wouldn't you think...Better than helicoil? Owning a Range Rover is the land based version of a boat...a hole in the road in which to throw regular bundles of money! |
3rd Sep 2014 2:49pm |
Usually caused when the plug has not been torqued up to the correct tightness and it starts to work loose and eventually spits it out. Alloy heads are very easy to damage when changing plugs and I always torque to the recommended setting |
3rd Sep 2014 6:07pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
I have had one in the past on another car, can't remember what, where the plug had been over torqued and had basically stripped the threads and a new plug wouldnt torque in properly.
5th Sep 2014 9:18am |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 |
On a previous car (FF) I had a plug detach itself from the head - had a slight misfire then engine warning light came on and off etc.
31st Mar 2015 5:02pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
It happens on a top gear special with Jeremy clarksons Mazda mx5 |
1st Apr 2015 7:03am |
