Home > Wheels & Tyres > 255.50.20 or 255.55.20
JAYBOY
I'm in need of some new rubber.
I'm running 255.50.20 at the moment but there are some 255.55.20 on fleebay at a very reasonable cost.
L405 runs on 255.55.20 so have anyone put these on their L322 and what are they like
Thanks in advance
Jay Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #278437 1st Sep 2014 11:59am
JAYBOY
anyone Question 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #278498 1st Sep 2014 4:51pm
craig reckons they ride more smoothly, thread on here somewhere... ... - .- -.
Post #278500 1st Sep 2014 4:55pm
http://www.fullfatrr.com/forum/topic26461.html ... - .- -.
Post #278501 1st Sep 2014 4:56pm
What happened to the 22's Jay?
Post #278559 1st Sep 2014 11:33pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I have had them on for over a year no problem.
I suspect my odometer under reads by about 10%, may have been the same with the last tyres, when comparing distances to planner distances but reckon speedo is still accurate.
Ian
Post #278588 2nd Sep 2014 8:31am
this chart shows the speedo difference between the 50 and 55 profile ratio,
speedo's are meant to under read so the 55 ratio will bring it up to more or less a 'true' speed. ... - .- -.
Post #278591 2nd Sep 2014 8:41am
JAYBOY
Craig
Winter is coming and i need to have M&S tyres on where i live.
2018 Skoda VRS
Post #278703 2nd Sep 2014 7:34pm
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
255/55-20 is great. It gives a smoother ride - does not rub at all Smile Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #278718 2nd Sep 2014 8:44pm
RiccartonRR
^^^ Stan - that doesn't make any sense at all.
As your tables correctly show the 55 has a larger diamter / circumference than the 50 and will therefore do less rpm for any given speed. The speedo takes a measurement of wheel rpm and calculates the speed from it via a fixed formula.
Therefore, if your speedo is accurate and shows 70mph when you are doing 70mph then with the 55s fitted you'd be doing 70+ when the speedo shows 70!!!
Speedo's are meant to errr on the side of caution so when it reads 70 you will actually only be doing 68 or so - not the other way around.
Soz!
Post #278719 2nd Sep 2014 9:02pm
so when it reads 72.34 mph [55 profile] it will be a true 70.. Confused
maybe someone with a satnav/gps and 55's can let us know the true speed at 70mph.. ... - .- -.
Post #278720 2nd Sep 2014 9:06pm
ksskaret
Well, I do have the 55 and they are dead on. I have a MY2010 and did the calibration in the settings menu. Checked with my iPhone GPS and compared with the speedo Thumbs Up
Guess the 55 is approx 4% larger than the 50 Range Rover TdV8 Autobiography MY2010
Post #278722 2nd Sep 2014 9:17pm
RiccartonRR
No - the other way around - when it reads 70 (speedo) the car could in fact be travelling at 72.34.
However, as all speedo's err on the side of caution the reality is that with 55's instead of 50's the speedo may actually read 70 when the car is doing 70 which is kind of what you said at the end of your post but for a confused reason.
Soz, not trying to be awkward or confrontational.
Post #278723 2nd Sep 2014 9:20pm
Yes I think some of you are thinking this the wrong way round , one revolution of the drive shaft ( which is where the pulse for the speedo comes from) on a 55% tyres will result in a grater distance covered by the out side diameter Thumbs Up 2008 MY Supercharged
Post #278742 3rd Sep 2014 2:42am
ebajema
Gents, apart from the ratio differences, the speedos always have a few percent difference as well. It used to be up to 10% but seems to have reduced to the range of 2 to 5% mostly.
My suggestion is, to use a GPS speedo app on your phone to see what the real speed is compared to indicated. That way you also account for the speedo indication difference at the same time. GPS speedo is pretty accurate I believe since it is based on super accurate timing and pretty good locational tolerance as well. It would be interesting if someone can actually tell how accurate GPS derived speed info is (I calculated less than 1% off but I'm not a specialist on GPS signals).
Speedos are normally indicating higher speed than you are actually travelling at in my experience and that is from using GPS/Nav apps plus reading many car test reports. Every report I can remember the speed shown on the speedo is higher than actual speed but I won't go into the accuracy of the measurement of the real speed the way it was measured (the used to roll this "5th wheel" contraption behind the cars). MY 2010 5.0 SC Galway green and sand interior!!
Post #278744 3rd Sep 2014 3:24am
