![]() | Home > Other Site Sponsors > New firmware & app release, V3.0, for the IIDTool... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8352 ![]() ![]() ![]() |
It is rather galling to be treated like a second class citizen just because you didn't buy the BT version
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
Pete, drop Patrik an email asking to be included in the beta program. He should then create a link for you to install v 3.0 (beta). To be honest, apart from the USB-Laptop thingy (which I am yet to try), I haven't found much difference, apart from having to press the (-) instead of the (+) to move "forward" through the menus. I haven't fully explored things yet, as too busy clearing "reservoir pressure static" faults |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Pete, I've got a none BT version but was able to upgrade to version 3 on 26th July all working fine.
Jo, Cheers, I know what you mean, just a bit upset that they seem to have forgotten about us...
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
Hi bud, you likely need the newest updater, thread on here somewhere |
I did, had it on the laptop and updated the installer... still says 2.7 is the latest...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
make sure you completely delete the old updater .. ... - .- -.
Stan, I read your post earlier about that, I did that on the laptop, then thought maybe I hadn't properly, so I put it on the PC which hasn't had it on before...!!!! Pete
email the gap chaps pete, i'm sure they will help.. ... - .- -.
Cheers, I will... Pete
Pat,
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
So if I've read that right, multi vehicle will not be supported on the non BT version, as it's not possible, even with the new software release installed ?
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
Not quite, here's our new VIN lock policy: Standard diagnostic functions (free of charge on any supported vehicles*) • Fault read / clear • Live values • Control outputs • Service / test functions Enhanced diagnostic functions (one free VIN, extra VINs are available if needed*): • ECU Re-flash (when possible) • Component and system calibration (including suspension height adjustments) • Advanced functions including backup / restore, save profiles – vehicle system settings and configurations are read and stored as a backup file for a restore function, various changes to systems (e.g. suspension height) can be stored and changed quickly * IIDTool BT: Can be used on any supported vehicle type (L322, L320, L319...) Regular IIDTool: Can only be used on the same vehicle type the tool was destined for. For example, a regular IIDTool for Range Rover 2006-2009 can only be used on those vehicles. Hope this clears things up. Cheers |
Ah, I read multiple vehicle with a different meaning in your post above. You mean multiple vehicle types.
