Home > General > 06 FFRR Diff Problems?
philrover
2006 Range Rover HSE 4.4 V8 Chawton White
I purposely went for the 06 onwards model in hopes that i would'nt not worry about the dreaded diff issues.
My 06 is starting to behave like it has an issue with the front diff.
1. I have this whine/vibration that's apparent on take off, changed all 4 wheel bearings but no change.
2. it is reduced to a faint hi pitched whine at a faster speed and is only audible when on the gas, it disappears when off the pedal but it sort of comes back at high speed coast down.
3. I feel the vibration at low speed on the steering wheel
4. There is an on/off slack on the drivetrain
Ive flushed the trans fluid, transfer case and recently changed the diff oil with the latter giving the most noticeable change. The general smoothness of the drivetrain seems to be gone.
Anyone experiencing this?
Thanks... 06 FFRR HSE
04 Freelander SE3 V6
97 Defender 110 300tdi
01 BMW 523i Touring
97 RR 4.6HSE
Post #27859 11th Sep 2010 5:57pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Check the prop shaft UJ's too. Get a good lever in there and give them a rattle.
The on off slack to me suggests UJs or mounts for the suspension frames.
If it is the Diff you can check this by chocking the wheels, Undo prop, jack front wheels clear of the ground. Make sure the car is safely chocked up. Get someone to roate one front wheel such that the diff input pinion roates. Listen carefully... if it is the bearing it should be fully apparent. If it is slight you can amplify the sound by holding a wooden pole against the diff case and the other next to your skull.. you will clearly pick up any uneaveness from the bearing then. If it is cyclic as in making the same odd noise on each roation of the input pinion then you can pretty much bet a pound to a pinch of Censored that it is the input bearing. These are replacable by specialists but there is a collapseable spacer inside which requires smoke and mirrors to replce. (I did my own on a 101).
What sort of milage have you got?
This is just bad luck if it is the bearing, its actually not the same problem as the Diff / prop issue on the earlier models, which was the prop its self getting chewed up.
Interesting if it is the UJ's as I suspected it would only be a matter of time before they began to fail.. they are often replaced on older Landy models. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #27861 11th Sep 2010 6:19pm
