Home > Technical (L322) > Auto Box dropping out of drive
tyso8879
England 2007 Range Rover Vogue TDV8 Barolo Black
My 2007 RR TDV8 Vogue will not stay in gear when I put it in drive it will be okay for a few minutes but then jump out of drive revs go up and the D off the dash dissapears. If I pull back on the gear stick it goes back in, until it drops out again going over a bump or braking. Any ideas please and how much is it going to cost me??
Post #278496 1st Sep 2014 4:43pm
try this,
http://www.fullfatrr.com/forum/post87201.html#87201 ... - .- -.
Post #278499 1st Sep 2014 4:54pm
Mikey
Parts are less than �11, and 30mins to replace Thumbs Up
Post #278508 1st Sep 2014 5:34pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I had the same with mine - a few squirts of WD40 as Stan suggested and job done and a huge relief! 4.2 Supercharged Vogue SE
Post #278511 1st Sep 2014 6:24pm
Worst case is that the link rod is bent, and you need a new one.... .
Post #278546 1st Sep 2014 9:26pm
tyso8879
Stan, You are the man worked a treat and was a bit of a relief to be honest I was expecting ������ as most things with RR. Great forum thanks.
Post #279004 4th Sep 2014 8:00am
glad its sorted and welcome to the forum richard.. Thumbs Up ... - .- -.
Post #279005 4th Sep 2014 8:02am
