Home > Technical (L322) > Replace upper rear wishbone bush at hub carrier in 30 mins |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Super write up. Well done. |
1st Sep 2014 5:41am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
put into the wiki.. ... - .- -.
1st Sep 2014 7:15am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Great write up. What were the symtoms to indicate these needed replaced?
1st Sep 2014 9:08am |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 161 |
Googsy, symptoms were as per the pic below.
1st Sep 2014 11:31am |
Stan, Wow I'm honoured. Thank you. Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! 😳 Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
1st Sep 2014 11:33am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
Top job! |
1st Sep 2014 1:20pm |
I'm hopping to get a Wiki entry some day maybe when Stan is older and more forgetful Present :2008 TDV8 HSE
1st Sep 2014 3:36pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
And when they have been gone a while they start to knock every time you go round a corner at lowish speed, mine were like it when I bought it.... you can check the play with a pry bar against the upper wishbone... Good writeup by the way Dijit.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
1st Sep 2014 4:29pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
Great write up!
1st Sep 2014 10:08pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Excellent photos and step by step guide, thanks. |
2nd Sep 2014 2:27am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Top job, great write up and pitures say a thousand words so easy job to do aswell If it dont work.......burn it!
2nd Sep 2014 7:35am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
good write up cheers.
2nd Sep 2014 8:10am |
johnboyairey by using two sockets you have perfectly parallel faces to pull against as the larger socket is held flat on the wishbone side thereby minimising and chance of the bush skewing. Am in favour of thoroughly cleaning the hole the bush goes in but in a non-aggresive way. anything which removes more than crud is to be avoided. Similarly take care with grease etc any many will cause the rubber on the new bush to perish. I used WD40 in the hole but on reflection i might have used a smear of Copperslip instead.
2nd Sep 2014 9:04am |
Forgot to report that it sailed through its MOT today. Job done! Rehab is for quitters!!!
2nd Sep 2014 11:02pm |
