Home > Maintenance & Mods (L322) > AIR SUSPENSION INACTIVE!!
Plumber cae
Wales 2002 Range Rover Vogue Td6 Zambezi Silver
Hi guys!! Every four weeks since I've owned this car something has gone wrong 😡 this time it's the suspension, woke up alarm going off so I just unlocked and locked again. Went out in the morning to find it praying, face down ass up. "Air sup inactive" so done the left to right trick and hey presto it worked. Happy days......... Next day same thing!!!! I noticed the NSF was going down quicker than the front so checked for leaks and there were none so took a gamble and bought a new oem bearmach height sensor, fitted it then turned the car on................ Car went straight up levelled out!!! The moment of happiness only lasted about 3 seconds then the "air sup inactive" was back up! But this time I could not change ride height it was locked and kept flashing. So took it to local specialist who put computer on it and told me that there was "no voltage to near side height sensor"!!! And told me that investigation work had to be carried out! It's booked in for next week at £60 an hour!!! Any common faults I can check? I really need help as I've spent about £2000 in 5 months on the f****** thing! Cheers guys. Recent work was new front diff and cv boots.
Post #278106 29th Aug 2014 10:04pm
Sure it wasn't, no voltage FROM the height sensor, that would just mean it needs a new sensor, if it's no voltage to, then I would think it would be a broken wire somewhere
Well worth investing in a IID tool, will save you tons in the long run... Pete
Post #278108 29th Aug 2014 10:16pm
Plumber cae
Cheers for the reply Pete. It was TOO and that was the new sensor I put on, I know but I don't know which tool to get?? The hawke or lynx
Post #278110 29th Aug 2014 10:22pm
Personally neither, I'd get the IID tool it works great.... cheapest is here
http://www.island-4x4.co.uk/integrated-int...-6425.html Pete
Post #278111 29th Aug 2014 10:32pm
Plumber cae
Just had a look, it says it uses the dashboard screen does it mean the sat nav or those under the clocks? If it's the clock screen then I have another job to do before I buy it!! Fixing the pixelated screen lol!!!
Post #278112 29th Aug 2014 10:40pm
Plumber cae
Right, just got under it and found a load of insulation tape wrapped around the height sensor wire near the plug, removed it and found 1 wire just hanging there and another bare with solder on it which goes into the plug looks like the hanging wire has come from the solder. I'm guessing this is not the correct way LR had originally done it. Does anyone have a wiring diagram of these plugs please.
Post #278197 30th Aug 2014 3:17pm
Here you go. Sorry about the quality, something to do with uploading to this site.
If you need the wiring diagrams for your vehicle pm me your email address. Thumbs Up
Post #278200 30th Aug 2014 4:19pm
From wiki
http://www.fullfatrr.com/forum/post275502.html#275502 .
Post #278202 30th Aug 2014 4:27pm
Plumber cae
Cheers guys real help, I got your emails thank you David, just bought myself the iid, pixel fix ribbon and height sensor repair plug. Will let you know how I get on!!
Post #278218 30th Aug 2014 6:27pm
Pixel fix ribbon is the hard one apparently... it's a nightmare getting the binnacle apart, especially getting the needles off without breaking them....
Luckily only got one line of pixels out on mine or I would have had a go already...
Can't find any "how to" that shows the full procedure just changing the ribbon which is the easy bit....
So if you do it... plenty of pics please... Pete
Post #278226 30th Aug 2014 7:49pm
Plumber cae
Once it arrives I will, a full video was promised from where I bought it. Will let you know.
Post #278232 30th Aug 2014 8:21pm
Cheers mate, good luck with it... Pete
Post #278233 30th Aug 2014 8:25pm
JAYBOY
My god that cars a pain in the ass.
At least its keeping you out of the pub and the house and work.
Rolling with laughter Rolling with laughter 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #278336 31st Aug 2014 6:05pm
Plumber cae
Your telling me!!! I'm working just to fix it!!
Post #278365 31st Aug 2014 8:08pm
