![]() | Home > Wheels & Tyres > steering wheel wobble |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
Shouldn't need to replace all four. Even if the spare is a different rim size, if it is fitted with the correct tyre (and the others) the overall wheel/tyre circumference will be the same.
retro man 1973 Member Since: 28 Aug 2014 Location: sussex Posts: 4 ![]() ![]() ![]() |
Yes I drove up motorway and all of sudden the steering wheel wobbled like crazy and banging noise from front wheels |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
Sounds worse than it probably is, suspension arms most likely, maybe puncture caused wobble, looks like you have 20" rims, tyres not too expensive for them (relatively) There are some well priced used ones on sale here at the moment which will be good, let us know what info you need as we have all been through everything |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
Last week I had a puncture on the rear of my 03 TD6.
@ retro
Thanks all, checked the suspension arms and was the lower arm, and balljiont on other side, replaced and all working, thankyou so much |
