Home > Maintenance & Mods (L322) > Suspension probs
mudknight
2003 Range Rover Vogue Td6 Java Black
Suspension probs
2003 TD6 with messages coming up , suspension inactive and also HDC inactive at the same time ,, can't put it down to any particular speed or distance traveled , sometimes happens straight away , other times after half hour on motorway ,, when I stop and turn key off then restart it clears it for a while ,, any ideas please
Post #277777 27th Aug 2014 7:35pm
What state is your battery in? (beats stan to it!) Wink
That is the first place to look, check that all your electrics are OK, alternator kicking out a good voltage.
HDC Inactive on startup usually a sign of low voltage.
All the ECUs are in a chain, so a problem in one place may cause others to appear.
Once you are happy that your electrics are OK, further diagnosis is possible.
Do you have an IIDTool (or similar) or access to one? The actual fault codes will help to understand where the issues lie. .
Post #277792 27th Aug 2014 8:20pm
mudknight
Battery in good condition , only six months old , checked what I can with electrics , hdc warning isn't on start up ,
Post #277925 28th Aug 2014 7:10pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Compressor in boot, has it been replaced at any time do you know? Dont think it would affect HDC though, they do tend to eat compressors in my experience Bow down
Post #277927 28th Aug 2014 7:23pm
mudknight
Compressor not been replaced since I've had the car and have no receipt when bought her either ,, suspension works fine when I alter the height ,
Post #277928 28th Aug 2014 7:30pm
