Home > Technical (L322) > 2003 FFRR TD6 - Mirror Fold Button
davemfox
Hi,
I have the above FFRR and the mirror fold button doesn't work. I've checked the fuses in the glove box and they are all ok - anyone got any ideas on how to fix this or if it's the motors in both mirrors that's gone?
Thanks,
Dave 1993 YZF 750 SP
Post #27475 8th Sep 2010 11:51am
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Just a guess - but considering you also have a problem with your air suspension (HDC Inactive message)
The button to activate the access height on your RR is next to the mirror fold button which are both located on your drivers door amongst the window switches...
...maybe (& hopefully) some rain water etc. might have created some gremlins within the switch pack?
Post #27479 8th Sep 2010 12:35pm
davemfox
Yeah good point. The access height button works ok, as we use that regularly.
Just to add a bit more into this. The original switch pack had the button broken off for the mirror fold, so I've swapped the pack over and all of the other functions still work, apart from the fold!!!
Post #27481 8th Sep 2010 12:40pm
davemfox
There must be someone on here who's had this issue with a 2003 model??
Post #27714 10th Sep 2010 11:06am
daveo
HI, i think you can rule out the mirrors as it very unlikly for both to fail, i would put my money on the door switch, remove it and make sure the plug is in correctly and you dont have any corrosion, if you had navcoder you could test them.
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #27760 10th Sep 2010 5:15pm
davemfox
I'm on my second switch unit, what's the chances of both of them being duff??
Are there any other fuses/relays hidden that I need to check??
Post #27772 10th Sep 2010 8:03pm
