![]() | Home > My Range Rover > Hi, just new here with an 04 4.4 V8 Vogue |
Kiwi_V8 Member Since: 16 Aug 2014 Location: Auckland Posts: 37 ![]() ![]() ![]() |
Hi!
That was my next port of call if a sensor didn't sort it. Any pointers for a supplier of new wiring looms?
No as they are fixed (part of the front loom) on your aged car! You can buy a new rear loom cut the plug off and solder them together? |
DAn @ Duckworths. REar one is only about £20 |
Welcome Kiwi... Have you tried double tapping the elec fold mirror button in an effort to 'reset' the mirrors and restore order to the folding mechanism?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
That link says it is for the touch screen head units, yours won't be a touchscreen....
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 ![]() ![]() ![]() |
Welcome Kiwi |
Cheers for the replies.
^ 184.90 |
Sounds intriguing, does that get you free view as well? |
nope, I don't need tv in the FF and wont bother with that mod. If it dont work.......burn it!
Fair one, but I need to keep myself amused whilst my better half is popping into the shop!
Take off the rear spoiler, four 10mm bolts inside the hatch you get to when it's open, then spoiler pulls towards you to remove, take the wiper off, carefully lift up the cap, it's a small ball and socket arrangement with the water coming up through the ball... remove the arm and have a go from inside, I left mine soaking in hot water for a while and then 120psi through the airline sorted it out... been fine for months now...
Good news, got the rear washer nozzle 1/2 working. One nozzle is good, the other 1 has a broken needle firmly wedged into it. 100% better than what I had before, but I'll keep an eye out for a new one.
