Home > Technical (L322) > Remote receiver.
its me
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Remote receiver.
Can anyone tell me where the key fob receiver is on a 07 supercharged. I still have no remote locking/unlocking. I have tried everything else, the only thing left is the receiver. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #276840 21st Aug 2014 8:11am
sleepezy
When this happened on mine (also 07) it was eventually traced to the key battery being dead - still started the car but remote wouldn't work. Bought a key from Dan and £15 later for the programming we were done (2nd time round - took a bit for the garage to suss it all out)
Post #276846 21st Aug 2014 8:30am
the RF receiver is installed at the rear of the roof, above the roof liner, to the left of the vehicle
centerline..item number 10 in the diagram....
Post #276857 21st Aug 2014 8:50am
its me
Replaced batteries in both fobs even though they tested OK. I managed to pick up a receiver cheap so will try that this afternoon. What I dont understand is the way it failed. Put it in the garage unlocked one day and the next day it didnt work. Stan, Thanks for the pic. Did that come from Rave because if so its not on my disk. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #276878 21st Aug 2014 10:26am
diagram came from the WM which is linked here, http://www.fullfatrr.com/forum/topic17623.html
have you tried a battery reset? ... - .- -.
Post #276881 21st Aug 2014 10:36am
its me
I've got that manual on disk. I didnt find it. Regarding battery reset I guess that that has been tried several times over the past 2/3 months. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #276887 21st Aug 2014 11:00am
The same thing happened to me just a few weeks ago , more than likely you keys have lost sync with the car and after a battery re-set you should be able to do it yourself ;
http://www.fullfatrr.com/forum/topic3713.h...ey+re+sync 2008 MY Supercharged
Post #276921 21st Aug 2014 12:30pm
