Home > Technical (L322) > Adaptive light module |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
give ducky dan a pm , he might throw some light on this... ... - .- -.
19th Aug 2014 3:40pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Do you know for sure that you have the adaptive lights on your vehicle.
21st Aug 2014 11:42am |
mk1paul Member Since: 01 Jul 2014 Location: Hampshire Posts: 100 |
Hi
22nd Aug 2014 2:55pm |
i gather your headlights are like the diagram with the cornering bulb [number 5] in it,
22nd Aug 2014 3:13pm |
Yes that's right.
22nd Aug 2014 3:23pm |
sounds like you need to get some diagnostics done on it..might be worth investing in an iidtool which will allow you to get the codes and do loads of other stuff as well.. ... - .- -.
22nd Aug 2014 3:30pm |
I wondered if it was just the AFS module needs replacing.
22nd Aug 2014 3:32pm |
Exactly the same as mine. Given up as they work as normal lights and no ideas on how to fix or even confirm tha they are wired up and not just replacement lghts from another FF There is a difference between knowing your sh!t and knowing you're sh!t
22nd Aug 2014 4:14pm |
