Home > In Car Electronics (L322) > NCS Expert
Smegordead
United Kingdom 2002 Range Rover Vogue Td6 Buckingham Blue
NCS Expert
Hi All,
I've spent quite sometime (days) searching around for help, advice or guidance on using NCS Expert with an '02 L322.
I've got everything installed and firing up fine but I can make head nor tail of which setting to use as they are all BMW based i.e BMW, Mini or Rolls Royce.
So a couple of questions if anyone can answer that would be great;
a) what chassis needs to be selected for the L322?
b) will NCS expert work with the reslers USB interface?
That or I'm looking for anyone that has any RR experience with this tool.
Hope someone can help 2002 Range Rover Vogue
Post #276173 17th Aug 2014 4:27pm
maybe ask here,
http://ncs-expert.com/ ... - .- -.
Post #276194 17th Aug 2014 5:49pm
Smegordead
Thanks Stan,
I've sent them a message already but no answer yet - I didn't know if anyone had experience of it on here. 2002 Range Rover Vogue
Post #276217 17th Aug 2014 7:44pm
search reveals only 4 threads re this but hopefully someone will help,
http://www.fullfatrr.com/forum/search.php?...rch_time=0 ... - .- -.
Post #276223 17th Aug 2014 8:10pm
Smegordead
Thanks again - I have already been through those but no-one really discussing which chassis to select.
Stan you may be able to help on this one if I focus a different way - I'm made some changes in NavCoder and it seems it's removed the "light left on warning".
Do you (or anyone else reading this) know 100% if the IIDTool can re-enable this? I've seen all the warning within NCS Expert but without getting it to recognise the car I'm out of luck. 2002 Range Rover Vogue
Post #276226 17th Aug 2014 8:19pm
not sure if the iidtool can do this but have a look on the gap site using the drop down menu,
http://www.gap-diagnostic.com/products/iidtool.html ... - .- -.
Post #276229 17th Aug 2014 8:22pm
