Home > In Car Electronics (L322) > Installing bluetooth & DAB on 2002 L322 AutoDAB Go
bola
Hi
I have a 2002 L322 with a CD player and the phone kit (however it's not bluetooth). I've read that I can maybe install a ULF module to enable bluetooth however I thought the AutoDAB go looked like a good option?
It can be seen on ebay here: http://www.ebay.co.uk/itm/AutoDAB-GO-LAND-...3a9357641b
Does anyone have any experience of these? Will they be relatively easy to install to the L322 or are there any issues I should consider before taking the plunge?
Thanks!
Post #276038 16th Aug 2014 9:58am
Looks like you need to connect it up to the Aux In of your current setup. Now on an '02 you are unlikely to have this. You can get your radio unit upgraded to have Aux In by Baris on the forum.
You don't say if you have an HSE or Vogue - MID or screen - this can make a difference
Also not sure if the car would automatically switch to AUX IN when a call came through (if you were listening to CD for example), but should be fine if you mainly use the DAB.
(please update your car profile, makes it easy to help knowing what vehicle you have!) .
Post #276041 16th Aug 2014 10:34am
bola
Thanks for the reply.
I have a vogue with the basic CD player and 6 disk changer, no screen. Is it possible to just disconnect the changed and fit an aux in? I think I have seen this done before on BMWs?
Thanks
Post #276571 19th Aug 2014 9:38pm
