Home > In Car Electronics (L322) > TV Tuner (again, I know) installation
nwmgc
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Assuming I ever acquire the hybrid tuner, do I need to do anything other than swap the plugs over - such as disconnecting the battery?
Do please pardon my stupidity... Embarassed
Post #275958 15th Aug 2014 3:54pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Not sure about disconnecting battery but would advise that you wait for all of the units in the boot to shut down before unplugging any of them
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #275966 15th Aug 2014 4:39pm
Discotigger
It should be a straight swap for the old analogue unit. There's a couple of threads about mounting the new hybrid unit, as some people prefer to keep the old analogue units in place. They use velcro to fix the new unit alongside the old one. I removed the old analogue unit (it can be a bit faffly to remove the brackets to get the old kit out) and refitted the new hybrid unit in its place. Don't need to disconnect battery, but do leave all the electronics to 'go to sleep', just to be on the safe side.
Also, make sure that you're in an area of good digital signal when you first fire the hybrid unit up, otherwise you may think it's not working (like I did, till I drove a mile up the road and then it worked perfectly!!)
Just remember to get the right tv nybrid unit, check the threads for the correct Tuner unit codes, e.g. AH42 19C063...etc. Thumbs Up
Post #275970 15th Aug 2014 6:02pm
We sell Hybrid tuners if you want one sir? We are away until the 23rd "ish" so send me a PM if you are happy to wait until we are back sir Thumbs Up
Post #275972 15th Aug 2014 6:07pm
stcstc31
Ireland 2005 Range Rover SE Td6 Atacama Sand
craig
my car doesnt have one installed, should it be wired for it. its an 05 early touchscreen
and also by installing one is this how you get reversing camera?
Post #275974 15th Aug 2014 6:11pm
nwmgc
Thanks gang! Thumbs Up
Post #276150 17th Aug 2014 12:10pm
markc1973
Northern Ireland 2005 Range Rover Vogue Td6 Java Black
Thanks Cam-Tech-Craig
liaising with Lorna reference module.
Cant wait
Post #279134 4th Sep 2014 10:12pm
